Results 1 to 6 of 6
Thread: How to change rear shocks (wagon)
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Default How to change rear shocks (wagon)
    This is dead easy and i did both my rear shocks in less than an hour. You'll need a spanner set, jack and a socket set for conveniance if you got it. This is for a wagon, but i dont think this process differes much for the live axle sedans, so it might be of use there too.
    1. Chock your front wheels well.
    2. Lift up the flooring in the back of the car and you'll see 2 grey covers with 2 screws holding them on. Take them off to reveal the nuts underneath holding the Top of the shock in. Undo the nut(you'll need 2 spanners, 1 to hold the flat on the top of the thread and a second to undo the nut on the thread. You'll understand when you see it, very easy.) and pull out the 2 washers and rubber. Take note of their order.
    <Not sure why this isnt working, But if you click the X it still seems to work.....Odd!
    3. Place the jack under the axle on one side and lift it only a little bit, just to give you some room to work under there, i didnt even lift the wheel off the ground.
    4. Now losen the nut holding the bottom of he shock on and pull it straight off. If its a little stuck put your spanner behind it to lever it a little. Take note which way the washer goes on. The shock will just fall out now.
    5. Have a look at all the old rubber washers and replace as nessacary, install is the reverse of removal. When tightening the nuts back up, be sure that they are firm, but do not overtighten them, as you will only crush the rubber washers and split them.
    All done and didnt take as long as you thought. So more beer time. Any comments on whats different for sedans would be good to make this a little more universal thread.
    Reaper
    VrWagz1's Avatar
    May 2008
    wollongong
    ? testing???
    Reaper
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
    Couldn't get the bottom nut off, any ideas how you guys removed it? There doesn't seem to be enough clearance to get a breaker bar
    vs commodore ute
    Jan 2010
    nsw
    vs commodore ute
    Jan 2010
    nsw
    if you cant get a breaker bar in there go down to super cheap or auto 1 and get yourself some freeze and release bes stuff in the world there is instructions on the can how to use it
  1. WTB lowered rear shocks suit solid rear axle
    By VS SII in forum Swap / Wanted to Buy / Trade
    Last Post: 21-03-2006, 09:27 PM
  2. Gas or oil shocks for the VS wagon
    By digisol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-10-2005, 08:22 PM
  3. change shocks or not
    By GeorgeB in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2005, 04:50 AM
  4. VX Wagon Series 2 Stock Shocks
    By VXWAGMAN in forum Parts And Other Items For Sale
    Last Post: 28-09-2004, 07:54 PM
  5. VX Series 2 Wagon Stock Shocks
    Last Post: 21-09-2004, 11:38 AM
