both my brake lights arent working, just wondering before i replace, are the break lights seperate from the other tail lights?
When you get new globes (if that's what your "replacing") then you will need to get brake lights...They are brake/tail lights in one...
-Merry Christmas-
check the fuse!! common happen
Take the bulbs out and check them first. If they are blown the little filament inside will be broken. I had a problem with my tail lights or maybe it was the brake lights not working. It turned out to be the white anti-corrosion paste that someone had put on the bulbs had dried out and caused a bad connection in the socket. Cleaned the crap off and they have worked ever since.
