hey guys cant remember how to do this so can anyone say how to remove the front seats in a VS
Allen key - 4 bolts. Run the seat all the way back and take out the one closest to the dorr and half undo the 1 next to the consol. Then run the seat all the way forward to get to the 2 rears. Then get to the front next to the consol. (this stops the seat from flopping around on you when removing the rear 2 bolts.
and 3 Dangerous non ABS VN's
Grab yourself some alan keys and you should find 4 bolts per seat. One on each corner of the seat going into the floor. Slide the seat all the way back to get the front ones and all the forward get the rear ones. Hope that helps mate.
^^^spot on (88greenVN, but also robot-dude). Unless you have 2 people then you can just undo them all as the other person holds the seat steady...or maybe a slab on the seat for balance
lol opps sorry... didnt realise 88 bet me to it
Also will add here if they are real tight use a ring spanner on the end of the allen key to get a bit of leverage. But be careful it can spring out and hurt things.
just tried to get the fron passenger one out and i warped the allan key there in there realy tight
Yeah they are really tight, but i managed to get them out with just an allen key, thick leather gloves and a lot of swearing - I think swearing lots is the key
Impact hammer - you may have to load up the allen key - say half to 3/4 pressure/flex on the allen key and try and hit it on top with a hammer. Or try giving them a wack with a very large flat punch.
Spray it with wd-40/silicon spray whatever and leave it overnight. Get a pair of multigrips on the outside of the bolt and the allen key on the inside. Most of the force will need to go through the multigrips so make sure theyre nice and tight. Maybe give the bolt a couple of hits with the hammer too before you start. You only need to break the initial lock, once it is broken the bolt will come out fairly easily (hitting it with the hammer might be a good stress reliever too). The most important thing though is to always stop before the bolt starts to strip.
I never thought seats would be so easy to remove and install lmao.
Holdens go fast...very fast.
FORD:
First
On
Rubbish
Dump
:P
S> CLEAR REAR BRAKE/TAIL LIGHT UNITS ( Got both left and right, from a VR ute),GOOD CONDITION, $70PICK UP ONLY 2197 N.S.W. PM ME
hey, can anyone tell me how to remove the door cards if its possible on a vs acclaim? cheers ill get some pics up once there done.
remove the cap from the pull handle, remove the two screws inside, very carefully remove the little red/orange pice from the lock knob (small screwdriver should do the trick) then its all just clips around the edge-should just pull off with a bit of persuasion
hey ive jus tried pulling my front seats out and the bolts are a lil diff in mine
on the sides by the door on both seats the 2 allen key style bolts are there and on the other side by the centre console the ones at the bak are there and ive undone all off those but at the front on both seats thea is 2 bolts but cnt undo with a allen key or wrench not sure how to undo these can any1 help plz?
You're probably looking at 2 flat top pins, right? Infront of them is the normal allen bolt, there's a slit in the carpet and it sits below the carpet line.
ohh yehhh.. the man! thnks maldotcom2 that helped me 100%
pullin them out now haha
Boy, some of our new members have heaps to learn........
At least this is a good place for them to do it.
hey ill admit i got alot 2 learn.. neva really been a car person til cupl years ago and my vs the first commie ive had so yer why yu think i signed up at this place so i can get quick answers for things i dno bout lol
tried changing my seats yesterday and had same issue with the flat top pins. thanks guys
