Results 1 to 8 of 8
Thread: Fog Lights on an Acclaim
    VS Acclaim
    Nov 2007
    Default Fog Lights on an Acclaim
    Hey everyone,
    Just want to know which fog lights i can put on my VS acclaim, SS or the statemans ones. I got the relay just need to know how to install the fog lights and which ones will fit.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    the SS foggies are the ones that will bolt straight up, and its easy enough to get an SS front bar, or get the inserts and add them to ur existing bumper.
    the statesman front end is a fair bit different to the standard vs's, also the foggies are longer
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    I fitted my original foggies by just adding the SS bezels to my std bumper and then lining up the foggies with the holes for the 2 holes in the bottom of the reinforcement behind the bumper.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    VS Acclaim
    Nov 2007
    So basically if i get the inserts will they just go straight on? And then if so how do i bolt the lights onto the bar?
    VY SS
    Jun 2006
    Albany
    if you get the inserts you will have to cut holes into your bumper or you can pay someone to do it for you, its not that hard i did it on my car if you want some pics. as for the lights you can get original ones which are pretty expensive or but some cheapies as i did which work fine but you will have to make some brackets to make it fit. also with the inserts you will have to get them painted to match your bumper
    VS Acclaim
    Nov 2007
    How much of the bar do you need to cut and where about d you need to cut? Anyone got any pics or instructions with pics on how to do this??
    VY SS
    Jun 2006
    Albany
    there was a howto somewhere if you have a look around or try the other commodores site
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    wagon_wheel did the write up, and i believe its still in the how-to section.
    its not hard to do.. measure twice, cut once!
  1. Plan-fog lights in acclaim-is it possible?
    By adz_vy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-12-2008, 12:16 AM
  2. Dash PRND321 Lights, VT Acclaim
    By Riggy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-11-2007, 06:23 AM
  3. VS Acclaim brake lights not working
    By SMIT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2007, 11:10 AM
  4. Help wiring up Fog Lights to VX Acclaim
    By SIXAPPEAL in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-03-2006, 05:57 PM
  5. park lights don't work - VT I Acclaim
    By savage1987 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-05-2005, 10:50 PM
