jst wondreing, are the VS series III 5.0 engine a roller motor like the vt 5.0? or was that just the VT 5.0 upgade?
cheers..
Engine Location Front
Configuration V90
Engine Size (cc) 4987
Cam Pushrod
Engine Cycle 4 Stroke
Engine Type Piston
Engine Number VM-######
Cylinders 8
Valves per Cylinder 2
Compression Ratio 8.8
Power 179kW @ 5200rpm
Torque 430Nm @ 3600-3600rpm
Induction System Aspirated
Fuel Tank Capacity (litres) 75
Fuel Delivery Multi-Point Injection
Method of Delivery Electronic Sequential
Configuration V90
Cam Pushrod
Engine Type Piston
Engine Number VU-#######
Cylinders 8
Compression Ratio 8.4
Power 168kW @ 4400rpm
Torque 395Nm @ 3600-3600rpm
Fuel Tank Capacity (litres) 73
From bluebook
I have a series 3 vs statesman with engine number VM-###### which is
found in the series 1 vt's. From the above specs it can be seen that
VM-###### engine numbers have greater horsepower and torque.
Therefore I'm guessing that these are roller motors. So check your engine number.
to answer your question, yes. series 3 VS are a roller cam set-up.
no worries, cheers for that guys..
if it is a 195 kw option it is rolers setuo but takes 10 minutes to pull off a rocker cover and check
