Results 1 to 8 of 8
Thread: Timing Belt/Water Pump Cost/Place?
    Apr 2008
    Default Timing Belt/Water Pump Cost/Place?
    Hey guys,
    Thinking my 96 VS Wagon needs a timing belt soon, its on 203,000kms :P
    Do they normally replace the water pump with it? What other things usually get replace with the timing belt?
    Also anyone know what costs i'll be looking at or have any recommended repairers in the Brisbane area?
    Hope it ain't too much, as the vehicle itself is not worth too much now.
    Thanks
    Wol_low
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The VS has a timing chain not a belt. If you are referring to the accessory belt, the one you can see, then it will need replacing when it is worn or if the tensioner has gone past the mark that tells you it is stretched.
    Usually the water pump is not replaced when the belt is done, or even if the chain is done. The chain is not a serviceable item, IE needs replacing at a certain interval, it needs replacing when it is stuffed basically.
    Visit my Facebook page
    Apr 2008
    Oh, I was told it has a timing belt, and that it will go very soon.
    1996 VS Series II Commodore Wagon
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Nope....chain....unless it rattles it is fine.
    VP Exec
    Jun 2005
    If it is the accessory drive belt, it's literally a 30 second job to do. Even if you have very little mechanical ability. About $30 for the belt. You do need a 18mm ring spanner but the wheel brace, which is 19mm, can be used. The only potential difficulty is in determining the route of the belt.
    Apr 2008
    Quote Originally Posted by Cheap6 View Post
    Hey, yah, nah its not the accessory belt, that seems to have some life still left according to the markings.
    Thanks for the info guys!
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    I wouldn't trust the markings, I have bought new acc belt and the marking shows stretched.
    Best way is to look at the actual belt and see if there is any large cracks.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    Quote Originally Posted by AttaBoy View Post
    i think you got the wrong belt than there are about 5 belts for the ecotec's (from vs to vy)and about 3 for the the old 3.8
  1. vl timing belt?
    By starfire vc in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-06-2010, 09:06 AM
  2. Help with Noise after changing timing belt....
    By VQXTC in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-12-2008, 01:48 PM
  3. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  4. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
  5. New Timing Belt Installation
    By Dan355 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-11-2006, 12:11 PM
