Results 1 to 5 of 5
Thread: error codes 32 and 76
    VSII Exec
    Dec 2008
    Default error codes 32 and 76
    hi everyone,
    i have had the 'check engine' light come on the other day. my vs (v6 with gas) was idling so low that i'm supprised that it didn't die.
    anyway, had a look at the fault codes and got 32 and 76. i'm thinking that 32 (air flow sensor) is causing the 76 (fuel/air mixture not right). is this possible?
    so my plan is to go to wreckers and get the air flow sensor (the one that sits in between the air filter box and the engine). does it sound like a reasonalble thing to do? any idea how much i should be paying?
    thanks
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Before you replace it, do you have an oilable air filter? Try cleaning the sensor with some carby cleaner first, see how that goes.
    Visit my Facebook page
    VSII Exec
    Dec 2008
    no oilable filter, but i like your idea of trying to clean it first. it may even work because the problem was on and off (one day it started playing up, was ok the next day, and now it's not happy again)
    thanks mate
    vsecov6commo is offline swc666
    vs ecotech 3.8ltr
    Dec 2008
    campbelltown
    Default fault code 15 16 whats the ecu sensor?
    fault code 15 16 whats the ecu sensor?and how do you change it?
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Quote Originally Posted by vsecov6commo View Post
    See below
    Error Code #15 and #16 - Coolant temperature sensor high voltage / unstable voltage
    SW
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
  1. VS V6 Error Codes
    By vsiicalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2008, 10:25 AM
  2. ABS Error Codes
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2007, 04:20 PM
  3. Error Codes
    By DND in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-09-2007, 07:57 AM
  4. error codes
    By SWE11L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2007, 06:46 PM
  5. VR error codes
    By gogo64 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2005, 07:24 PM
