hi
got a problem lately my auto gearbox been having problems it wont shift into 1st and if it does it takes like 30 - 40sec to do so and wont go into 4th ethier can someone please help me....
1994 Holden VR Acclaim Ecotec V6
1992 Holden VP Berlina S2 retro fitted with VS Acclaim Interior
time to start looking for a replacement im afraid, how old and how many km's are on it do you know?
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
it was only just replaced with a second hand one
my statesman did this would rev really high then slam into gear took it to a trans specialist and they pin pointed it was the throttle position switch on the throttle body, changed it over never had a problem afterwards maybe not your problem but worth a shot if a mate of yours has the same car grab his sensor n give it a shot
Check the oil, autos don't like running low.
Check for error codes first as it may give you an indication of the problem. Use the instructions at:
Checking error codes VR/VS (Revised)
mite not be this but have you put a new filter in it
is it not engaging the gear ? or is it in gear and slipping ? sounds to me like its low on oil, I'd check the color and smell of the oil while its running in park and at normal temp, smell the oil for a dirty smell, if it was just put in it should be red or slightly pinkish, otherwise u might be looking @ the throttle sensor, you could get a diagnostic run on the box for electrical problems
