Results 1 to 12 of 12
Thread: power button how does it work, if it does?
    hectik turbos
    Aug 2008
    Default power button how does it work, if it does?
    what exactly does the econ/power button do in my vs i understand they are in other models too and makes
    different people have told me differnet things (does nothing, affects the shifts, changes air fuel ratio etc)
    it seems it may go a bit better with pwr on and uses more fuel but what does it do ?
    cheers
    WhiteVS's Avatar
    WhiteVS is offline Stockish
    Sacked VT Berlina
    Aug 2007
    Melb. Vic
    i think it just holds the gears out longer, someone correct me if im wrong.
    Quote Originally Posted by Jecs View Post
    i remember my first experience with camber. it was with my match box cars. i use to stand on them to lower em and it use to bend the 'axel' changin it from live axel to IRS lmaao.
    VS Calais S1
    Jul 2006
    Kadina, SA
    Quote Originally Posted by SV.ETiHW View Post
    yeah i dunno i could be wrong as well but thats my understanding of it
    VP Executive R-spec
    Jan 2005
    I changes both the speed the shifts change at and also the shift pressure (firmer shifts) that's it
    mazzstein's Avatar
    mazzstein is offline 5 Litre Owner
    VS V8 Barge
    May 2006
    Narre Warren
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    there are a million answers to this next question that I am about to ask on these forums, BUT!
    Once and for all, Foamy help me out here, is it safe to use PWR around town? and or on the highways or even, just push it in and leave it like that?
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Here is the quote from the VS Series Owners Handbook:
    """The transmission operates in two types of modes: power and economy. The PWR reminder light on the instrument panel will glow when in the power mode.
    Economy mode is recommended on normal or freeway driving, as it gives better fuel economy. Power mode has revised automatic transmission shift points, to give the car a more responsive feel."""
    So, in a nutshell, PWR will allow the engine to rev higher before it shifts to the next gear plus, as the engine is revving higher the shift will be more responsive (read jerky) due to the change in revs.
    For towing, the handbook recommends using "3" instead of "D"..... or "D" with the PWR mode on.
    VS V6 surf
    Oct 2008
    this is all true apart from one more factor ; when you have %80 or more throttle down its is the same as having the pwr switch on.
    hectik turbos
    Aug 2008
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Mine was driven in "economy" its whole life until I got it and now drive it in "Power" mode.
    When i shifted from power back to economy and put my foot down it blew my trans cooling line and lost compression.
    Now I leave it in power mode been good since.
    VS Commodore Omega
    Apr 2005
    I notice with power mode and the electronic shift kit the gears change harder than with just the electronic shift kit on its own. Also noticed it struggles to get into fourth gear unless pushed harder (so probably equates to bad fuel economy for highway driving).
    I always thought that power mode took away fourth gear but I guess it's just that I never go 95km/h with it on so wouldn't know better.
  1. Power Button???
    By the_ozz_man in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-06-2008, 06:43 PM
  2. Power Button???
    By CHARGEDVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2007, 04:55 PM
  3. Power Button !!!
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-06-2006, 02:33 PM
  4. Power Button ..........
    By Stimps in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-12-2005, 02:26 PM
  5. power button
    By seventh path in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-01-2005, 08:41 PM
