Results 1 to 7 of 7
Thread: any electric experts out there?
    alan smithy is offline alan smithy
    vs wagon
    Aug 2008
    footscray melb.
    Default any electric experts out there?
    hi all, my vs wouldn,t start yesterday. ignition on all the time. racv wired it to start. he tells me a pin in the barrel is stuffed. what i want to know is can this be repaired or is it a new barrel? i can still be mobile by pulling pump fuse (fuel) then disc. battery. otherwise ignition is on all the time. bit of a pain doing this all the time and hot wiring etc. all help appreciated.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    you can repace the ignition switch seperate from the ingntion barrell and it shouldnt cost an arm and a leg either.
    Apr 2008
    its the barrel thats stuffed, not the switch.
    you will need a new barrel, which if you like consistancy will mean new boot, door and glovebox locks, and a few new keys.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It is possible to disassemble the new switch and put the old pins in - some barrels come with an assortment of pins and you adjust to match your key....or take the old key and new barrel to a locksmith but be prepared to pay.
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    It won't be a faulty ignition switch or lock assembly. The part that is probably broken is the drive pin that actuates the ignition switch. It's cast as part of the lock assembly and because the lock is only made of lightweight alloy, the pin eventually snaps off in the ignition switch. You will usually find that when the pin breaks, it leaves you with the switch in the ignition position, but the key and barrel continue to turn to the start position anyway.
    The fix is a new lock assembly with the lock case, because the broken drive pin is part of the case. No other fix is feasible.
    vs wagon
    Aug 2008
    footscray melb.
    moff_man's Avatar
    Nov 2008
    Quote Originally Posted by Calaber View Post
    the drive pin is not part of the case they are 2 different things, the drive pin attachers to the tumblers which it what gets turned with the key. the case or barrel lock's in to the lock assembly. and they are still both a serviceable item a whole kit cost about 75 dollars and if you are clever you can code it your self.
  1. to go to gas or petrol for 200rw kw motor? calling gas experts
    By Horze in forum V8 Development and Modification
    Last Post: 03-05-2008, 09:36 PM
  2. Electronics experts: Transistor help plz!
    By shaggerz in forum Electrical Wiring / Questions
    Last Post: 21-03-2008, 07:18 PM
  3. BCM Experts?? Need some help :)
    By feistl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2008, 01:59 PM
  4. a little test for the car experts....
    By JD in forum The Pub
    Last Post: 15-02-2007, 09:56 AM
  5. Gearbox Problems Experts Please Help!!!
    By QIK51X in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2006, 06:05 PM
