Results 1 to 13 of 13
Thread: Ecotec Cold Start Problem
    VS Executive V6 Auto
    Dec 2007
    Newcastle
    Default Ecotec Cold Start Problem
    Hi all,
    I was on holidays and did not drive my car for a week. When I got back my cars was fine for one day.
    Now when I start the car when the engine is cold the idel is rough (it's like the car is running out of fuel). This morrning just after starting the car I reved the engine I noticed that the revs droped and the engine stalled.
    After about 30seconds the car runs fine.
    Any advice would be great.
    P.S. I installed a performance chip a bit over a month ago, but given that it ran fine with the new chip for a month I dont think this is the problem.
    V-Josh-R.'s Avatar
    V-Josh-R. is offline NEED PACEMAKERS.
    94-VR Commodore Ute
    Jul 2008
    Check your fuel filter for a clog or something, or something wrong with the rails?
    Holdens go fast...very fast.
    FORD:
    First
    On
    Rubbish
    Dump
    :P
    S> CLEAR REAR BRAKE/TAIL LIGHT UNITS ( Got both left and right, from a VR ute),GOOD CONDITION, $70PICK UP ONLY 2197 N.S.W. PM ME
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    VRII Acclaim
    Jul 2005
    Would be worth checking the fuel pressure regulator too. There is a vacuum hose running of it. Check this for fuel. If there is any fuel in the vacuum line, replace it. The regulator may be leaking a little bit of fuel back into the inlet manifold, flooding the engine. Once started the car may run rough as it burns all this extra fuel, but can use it up when it is running.
    Could check error codes too.
    '04 VZ Executive, '98 EL Falcon, '96 NF Fairlane
    Jul 2008
    Blue Mountains, Sydney, NSW, Australia
    Quote Originally Posted by mcvk View Post
    Hi all,
    It is the chip my mats el falcon had a very similar prob. the car was sputterin and stalling constanly be punched the computer (not too hard) and that fixed it. the chip might have a loose connection. Im not sure but i think it is a power chip in his car
    [Linkin Park] Concerts:
    [20.10.2007, Sydney Entertainment Center, Sydney NSW] [11.12.2011, Acer Arena, Homebush Bay, NSW] [15.12.2011, Acer Arena, Homebush Bay, NSW]
    Vehicles:
    [2004 VZ Holden Commodore Executive V6] [1998 EL Ford Falcon GLI Manual Inline 6] [1995 NF Ford Fairlane Ghia Inline 6]
    Dec 2007
    Newcastle
    The car definitly had fuel in it. However, this is the first tank of V power fuel I have put in it.
    I have also noticed that when it is running rough if I feed the throttle on the revs climb nicely but if I quickly go to about 50% throttle the revs drop and the engine wants to stall.
    VR Commodore V6
    Sep 2008
    Sydney NSW
    V-Josh-R.'s Avatar
    94-VR Commodore Ute
    Jul 2008
    Definetly sounds like a flooding issue. The car will roll the revs on slowly but when you gun it it cant burn the fuel and therefore no drive power?
    FORD:
    First
    On
    Rubbish
    Dump
    :P
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Quote Originally Posted by V-Josh-R. View Post
    Which could also be the plugs.
    Dec 2007
    Newcastle
    Just a reminder that it is only an issue when the engine is cold, after running for 30sec to 1 min it is fine.
    V-Josh-R.'s Avatar
    94-VR Commodore Ute
    Jul 2008
    Thats probably because after about a minute it has burnt up the fuel that is causing the flooding in the first place...?
    FORD:
    First
    On
    Rubbish
    Dump
    :P
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    tps blocked or throttle body blocked. i was thinking airflow meter before but the issue clears up which means to me it could be a particaley blocked tps.
    the check eng light isnt on is it?
    also it could be the plugs but its strange its only done this since its been sitting for a week with out a start.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Coolant temp sensor possibly?...the one that tells the ECU to lean the mixture as things are warming up.
  1. VT cold start problem
    By doug05 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-07-2011, 06:42 PM
  2. cold start problem
    By green vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2007, 05:10 PM
  3. Problem -S/Charged V6 Cold Start wont idle
    By colgf in forum General Discussion
    Last Post: 06-09-2007, 05:47 PM
  4. Cold Start Problem
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2007, 04:05 PM
  5. VP'SS' V8 '93 Cold/Hot Start Problem
    By NancyL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-05-2005, 01:55 PM
