Results 1 to 20 of 20
Thread: Changing the colour of the speedo needle
    <RaBBiT>'s Avatar
    <RaBBiT> is offline Follow the White RaBBiT>>
    95 VS Berlina 5.0,VN Wagon 5Spd 5.0L
    Nov 2007
    [SA]
    Question Changing the colour of the speedo needle
    has anyone know how to change the colour of the neeldes?? they are a very gay orange and want them to be a nicer red is it possible to do this???
    If Barbie's so popular, why do you have to buy all her friends?
    redcv6's Avatar
    redcv6 is offline supercharged intercooled
    vy ss ute, diesel landcruiser 100s, hq panel van
    Aug 2006
    Ringwood
    <RaBBiT>'s Avatar
    Nov 2007
    [SA]
    i won't rip them out lol fromm want i have seen it looks like there is like a sticker on the needle that makes it orange this true???
    VR
    May 2008
    I've changed the cluster face and ended up with the same problem. Gay orange. But I put it all back together with the intention of 'getting round to it'.
    It's been a while since I pulled the dash apart, but if I was to hazard a guess - you might be able to pull the pins out then wet&dry the back of the needles & maybe paint 'em. Probably wrong. Maybe you can buy coloured needles.
    In any case, I'm interested in a solution too ...
    redcv6's Avatar
    Aug 2006
    Ringwood
    <RaBBiT>'s Avatar
    Nov 2007
    [SA]
    i would rather take the needles out and paint them but is painting the only option???
    redcv6's Avatar
    Aug 2006
    Ringwood
    <RaBBiT>'s Avatar
    Nov 2007
    [SA]
    hmm sure seems like a tricky one hey but cheers for ur help
    VR
    May 2008
    Like I said. You'd probably wanna take the needles out, wet&dry the back of 'em so the light illumiates the needles. You're gonna be driving at night too, y'know.
    Again - I haven't done it. But I'm thinkin' about doin' it now ...
    <RaBBiT>'s Avatar
    Nov 2007
    [SA]
    yeah i would like it to be like a clear red hey
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    I have heard of people ( not in cluster of course) using a blade to scrap the orange off the original ones and use a special type of nail polish to cover it, also I know for a fact that you CANNOT get the paint on the sides of the needle as it'll stop shinning through, must only be on the underside.
    VRII Acclaim
    Jul 2005
    Take the instrument cluster apart, remove the needle, maybe try scrapping the orange off (as suggested) but use GLASS PAINT to spray the needle in your new colour of choice. Available from bunnings and probably auto shops too. Comes in a small spray can and is semi-transparent with a nice deep colour. Spray it and put it back it. Move the needle and make sure it re-zeros (ie goes back to 0km and doesnt get stuck along the range). If it doesnt re-zero just take it off and move the needle slightly left or right until it does re-zero. Should be an easy job.
    LightningVP is offline Donating Member
    None
    Sep 2008
    I have started to do this with some spare pins I had lying around, all I'm doing is using a razor blade/stanling knife to peel the orange off...havn't worked ot if it's a sticker or paint though, and it's a pain in the ass of a job, as it's quite thick
    <RaBBiT>'s Avatar
    Nov 2007
    [SA]
    Quote Originally Posted by kopper69 View Post
    Take the instrument cluster apart, remove the needle, maybe try scrapping the orange off (as suggested) but use GLASS PAINT to spray the needle in your new colour of choice. Available from bunnings and proberly auto shops too. Comes in a small spray can and is semi-transparent with a nice deep colour. Spray it and put it back it. Move the needle and make sure it re-zeros (ie goes back to 0km and doesnt get stuck along the range). If it doesnt re-zero just take it off and move the needle slightly left or right until it does re-zero. Should be an easy job.
    ahh cheers sounds like ur onto somthing
    one more question i have the berlina dash and was just wondering will the standard dash needles fit the my stage 3 dash?? or will i have to pick up level 3 needles its just a pain cos they seem to be harder to find
  15. #15
    None
    Sep 2008
    i believe all the needles are the same, except some are longer than others (speedo is longer than temp and petrol....)
  16. #16
    <RaBBiT>'s Avatar
    Nov 2007
    [SA]
    cheers let me know how u go with urs hey
  17. #17
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
  18. #18
    <RaBBiT>'s Avatar
    Nov 2007
    [SA]
    lens dye hey were that sold never heard of it hey:P
  19. #19
    VS Berlina
    Feb 2007
  20. #20
    <RaBBiT>'s Avatar
    Nov 2007
    [SA]
    ahhk cheers
  1. removing speedo needle
    By starfire vc in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-08-2009, 12:18 AM
  2. VR V8 BT1 Speedo Needle Below 0km/h
    By mess666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2006, 08:08 PM
  3. wobbly speedo needle
    By Lish in forum General
    Last Post: 19-02-2006, 12:55 AM
  4. speedo needle not functioning
    By bluecar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2005, 10:06 AM
  5. speedo needle
    By superchargedv6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2005, 04:12 PM
