Results 1 to 4 of 4
Thread: Tightening a Sunvisor
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Default Tightening a Sunvisor
    This may sound like an utterly stupid question, but is it possible the tighten up the mount on which the sunvisor rotates on? I have one of those Blueant Bluetooth handsfree kits attached to the visor and the weight of it causes the visor to flop down which is quite vexing. Any suggestions or should I just get another one?
    VP Exec
    Jun 2005
    Yes, but I can't remember exactly how . Try knocking the visor onto the pivot pin, further towards the outside of the car
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    try a larger pivot pin?
    wedge foam in there from an old pillow?
    customise it so as it is pulled down it "clicks" same as when it is pushed up, each click is a pin flicking along a gear, which will hold it in place, you could probably get an assembly that you could make fit somewhere.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It may be possible to somehow tighten the hinge part nearest the rear view mirror....maybe by removing the sleeve bit and replacing it with a split sleeve made from clear plastic tubing which has a larger outside diameter enabling it to by clamped tighter by the clip. The other hinge side may be able to be tightened by sliding something in alongside the rod....something like a thin feeler gauge or some thin plastic from a milk bottle
  1. VR commodore sunvisor bracket
    By Trei in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2008, 02:36 AM
  2. sunvisor
    By Bubbles in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-12-2006, 09:48 PM
  3. external front sunvisor
    By rexsportwrx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-04-2006, 09:23 PM
  4. WTB: sunvisor clips for my vh
    By PEAKN6 in forum Swap / Wanted to Buy / Trade
    Last Post: 31-12-2005, 01:05 PM
  5. wtd SUNVISOR CLIPS FOR VH
    By marinello red in forum Swap / Wanted to Buy / Trade
    Last Post: 22-12-2005, 08:28 PM
