Results 1 to 5 of 5
Thread: vs clubby problem
    vs clubsport
    Aug 2008
    Default vs clubby problem
    hey guys can rear end axle wheel bearings cause tight gear shifts in 1st gear stop still or not
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    I cant imagine any way this would cause first gear to be tight. Probably more so in the adjustment of the clutch cable if its a T5. If its a Getrag box then I know the rubber bushes under the shifter mounting area are prone to excessive wear resulting in the shifter being a bit loose and able to be wobbled side to side when in a gear. If this is the case I have been told it can contribute to first gear being tight and hard to get at times.
    Aug 2008
    NSW South Coast
    Should also make sure you are getting a full travel in the clutch pedal, i.e. dont have any really thick floor mats under it that stop it from hitting the floor. Just a thought.
    vs clubsport
    Aug 2008
    ok champ no worries i noticed its only tight in sumtimes only dat 1st gear i got my clutch cable adjusted it seems to be alot better then before but u rekon worn rubber is it expensive to change
    Aug 2008
    NSW South Coast
    I have not actually replaced these rubbers on my shifter yet so i've got no idea about the price sorry. Cant imagine they would be too much, maybe $40 at a random guess.
  1. vs clubby gearbox problem
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-11-2008, 12:29 AM
  2. VS clubby tune problem
    Last Post: 28-10-2008, 08:37 PM
  3. 96 S2 Clubby
    By Sedat in forum VR - VS
    Last Post: 07-02-2008, 08:01 PM
  4. vy clubby kit on vp?
    By tweakt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2005, 11:26 AM
