Results 1 to 13 of 13
Thread: whoops... wrong polarity
    VZ SV6
    Oct 2008
    Newcastle NSW
    Default whoops... wrong polarity
    hi, i got a dead cell in the battery and bought a new one, and of course me being stoopid hooked up postive to negative and vice verca. got a nice few sparks and 'zaps' before i realised the terminals wouldn't fit for some reason... then i realised why.
    before i reconnect it the correct way... what have i probably rooted? is it wise enough to just connect it the correct way and see what happens?
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    probably wont hurt at this stage to just hook it up correctly and see.
    Check your fuses too.
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    VRII Acclaim
    Jul 2005
    As DannyboyDS, put it in properly and cross your fingers. Im sure there was someone else not too long ago that did the same thing, fixed it up and all was fine. At least you will only do it once!
    VZ SV6
    Oct 2008
    Newcastle NSW
    haha yeah it seemed so obvious in hindsight and feel stupid now oh well learning curve. put it all in correct way and all seems well except a blown parking light after checking all electrical systems.
    also i realised i don't have my radio code and for some reason every other time i disconeected the battery it didn't need it. Oh well no tunes until that's obtained.
    VR Berlina N/A V6 3.8
    Feb 2006
    lol... i have done that and couldnt understand y the abs fuse blew... worng way..lol nothing else damaged thank god...
    VT Calais
    May 2010
    so ive done this same boneheaded move. my radio is gone, my battery indicator light has stayed on, and as i was parking last nite, the low fuel indicator popped on, then off, gas guage dropped to nothing (quarter tank in), and the headlights got dim.
    i understand its the alternator, but before i go and tear it down. does the alternator itself have a fuse? (wrong cables hooked up for about 10-13 seconds, and smoke did come out of the alternator), or have i fried my alternator?
    im in lithgow, is there any where to purchase rebuilt alternators for a reduced cost? (in case mine is fried?)
    1999 Commodore
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Nickhead View Post
    1999 Commodore
    I reckon the alternator has fried. If you can't afford a new one then try some wreckers.
    MY RIDE
    VT Calais
    May 2010
    Default i was prepared for the worst.
    i figured as much. im originally from the states, so i need to stop thinking 'backwards' and no more bong hits before maintenance.
    i know back home we would buy them reconditioned, is that not an option here?
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    yep, alternator will all cooked and crispy.
    you could try an auto elec for a reco, but they may end up charging you more cause they won't be able to rebuild yours.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    there is a fusabol link on the positive lead that usually frys (100% on the v8's not too shure about the vs v6's)
    just checked my vr and its the little red wire on the +'ive that goes in to a single plug that connects to a white wire
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    1999 Commodore
    Check your regulator and brushes before thinking the worst.
    VS-II Esteem
    Apr 2010
    Tasmania
    Yeah, I was going to say the regulator/diode pack in the alternator would possibly be fried!. Your fusible links should be fine, as they're only thick wire that will only break if you get a massive over voltage, in general anyhow. I'm surprised you didn't just blow a few fuses. Worst thing that could happen is that your computer box gets totalled!.
    Cheers!
  1. Is It Wrong? Let Me Know What You Think
    By ASIAN_VP in forum General
    Last Post: 19-03-2007, 01:15 PM
  2. Speaker wire polarity
    By Sorak in forum Car Audio
    Last Post: 01-11-2006, 12:54 PM
  3. wrong mix
    By samvlcal in forum The Pub
    Last Post: 04-10-2006, 08:38 PM
  4. Is this wrong?
    By minux in forum The Pub
    Last Post: 20-07-2006, 03:05 PM
