Results 1 to 7 of 7
Thread: the diff
    System's Avatar
    System is offline Control is a way of life
    2005 VZ commodore exec
    Oct 2007
    Default the diff
    hey all, i have a 93 VR acclaim sedan, and the diff is startin to clunk away quite heavily. The trans is new, the motor has done bout 170,000 (the car has done 300,000) so i'm guessin its due for it to shake rattle and roll. a few times i've had it clunk, 99% of the time is when i'm slowing down, then i speed up suddenly, it actually sounded like a 'metal on metal' clunk. The oil is fine so i'm guessin its just a tired diff lol (the uni joint is also startin the 'loose rattle' on the under-body every now and then).
    I do plan to keep the car for quite a while yet mainly because of the parts that have been put in (plus the exhaust has had some work done to it recently ). How much would a new diff/tailshaft cost?
    oh and also, when i go to put the pedal to the metal, the car takes its time to change back. Would that just be the old diff, or is that how stock standard parts for a VR operate? lol
    cheers.
    Unions: the people who brought you weekends
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Uni joint fail = car stopped. I'd fix tht first and no kick backs until fixed - long walk home as they say
    and 3 Dangerous non ABS VN's
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As 88greenVN say, replace the unis first. The slow change back when pedal to the metal sounds more like a transmission problem - I'd talk to the place that reconditioned it. The diff will not cause this problem.
    System's Avatar
    Oct 2007
    Quote Originally Posted by hako View Post
    it was actually a trade in recond trans, and the warranty will be looong gone now- its been a year since it was done.
    how much would a uni joint cost? i heard its not that much, just the pain in the ass job of installing it.
    Farlig's Avatar
    Farlig is offline Donating Member
    Y-Series Clubsport
    Jan 2005
    that sort of noises and clunks, usualy means driveline looseness, as said uni joints etc.
    mostly a labour intensive job. have a chat with jackson
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    If it turns out its the diff, Boss Racing Diffs is the place to see.
    They'll probably be able to do it if its a uni, but you might be able to do that yourself.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    Uni's usually set you back around $50 each, best bet is to locate the one that is failing and replace that, if you have some spare cash, replace them all :P
  1. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  2. question about diff gears in a irs diff vs 5.0l
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2008, 04:21 PM
  3. VT-VZ IRS LS1 Diff will it bolt up to V6 IRS Diff cradle?
    By cxcxcxvcvcvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2008, 09:51 AM
  4. WTB: 3.73 Diff Gears Suit VS Diff
    By Wagon_Wheel in forum Swap / Wanted to Buy / Trade
    Last Post: 11-08-2008, 02:51 PM
  5. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
