Results 1 to 7 of 7
Thread: standard L67 eprom vs Xu6 eprom?
    VS l67 statesman
    Dec 2008
    Question standard L67 eprom vs Xu6 eprom?
    Does Anyone know if a xu6 eprom will out perform the standard supercharged 6 eprom? my motor has the following mods CAt backs ,extractors,69mm TB,msd coils,9mm leads, 10psi pulley, with future plans for high ratio rockers
    also is it safe to buy one of ebayer?,there is a guy that will reprogram your standard one, any feedback from anyone who done this would be appreciated ,whethers its good or bad thanks
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Isn`t the XU6 a turbo motor not a charged motor? therefor the emproms are completly different?
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    VS l67 statesman
    Dec 2008
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    The XU6 has a more free flowing exhaust with extractors and twin HSV exhaust fitted otherwise the rest is the same as a stock L67 VT/VX.
    The XU6 eprom is probably setup to take advantage of this change so will probably work ok with the mods you have.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    VS l67 statesman
    Dec 2008
    thanks for the links and advice,sounds like I might give it a go
  1. how to program a eprom
    By RabidDog_12345 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2007, 10:11 AM
  2. VS V6 eprom chip code? 27c??
    By ragex in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2006, 08:05 AM
  3. Eprom Emulator instead of chip
    By VN_Luke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2006, 02:41 PM
  4. DIY $20 EPROM eraser
    By pete_pumpkin in forum General Discussion
    Last Post: 22-12-2005, 09:40 PM
  5. EPROM diagnostics
    By muney in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2004, 09:48 AM
