Page 1 of 2 12 LastLast
Results 1 to 25 of 43
Thread: Performance Upgrade Questions?
    VS Ute Olympic Edition
    Nov 2008
    Default Performance Upgrade Questions?
    Hi
    I would like to ask a few questions.
    i would like to know the bennifits of replacing the stock standard fuel injector's.
    what other upgrades will be needed?
    i already have cold air induction.
    gettin high ratio rockers 1.9:1
    i would also like to know if anyone know's of a place you can get a full high performance pully kit for V6 ecotech.
    cheers
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Would you be replacing the injectors with new/reconditioned standard ecotec ones or new ones with a higher flow? IMO if your replacing them with new standard injectors you will probably pick up a small amount of efficiency/performance as the old ones currently in it are most likely not all flowing even and have a different spray pattern after years of work and slowly collecting and clogging up with random impurities in the fuel that make it past the filter so I would recommend doing this even for the sake of keeping your motor running in top condition. Upgrading to higher flow injectors it also good but you will probably find that without getting it tuned to suit it will run like a dog and be too rich, especially down low if you put your foot into it, it will have a flat spot and cough and splutter a bit before it gets going (i.e. too much fuel and not enough air). Also depending on how much you increase the flow rate of the injectors you may also need to upgrade your fuel pump to keep up with the demand.
    This is my experience from mucking around with injectors on a mates ecotec but others may think otherwise. Hope this helps.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    There is no benefit to fitting new/bigger injectors on a stock or slightly modified engine.
    You only need to replace injectors if they are rooted or the engine is modified to the point where the flow of the std injectors isn't high enough to supply a safe A/F ratio.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    I whacked in some VERY low k's VX injectors into my VS ecotec, runs ten times smoother, even better fuel economy then before, best money I ever spent, keeping in mind these injectors have a bee's dick less flow but spray the fuel better.
    Nov 2008
    cheers guys will take your adivce into consideration.
    i am more then likely looking at alot of modifications, to my car, engine, etc.
    so if you have any further sugestions on increasing the perfomance of a Vs V6 Ecotec ute.
    your advice n knowledge is welcome.
    i have a list a foot long of stuff i has to buy n fitt in the new year. as my car is off the road for 3 months due to lose of licnece. so i'm doin alot of work n upgrade to improve my car's performance. and looks.
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by Dazza07 View Post
    Learn what your motor is called. ECOTEC, no H on the end. CAI: good on you, you're a step in the right direction. If you want to do injectors go ahead but don't upgrade, replace with newer ones the SAME SIZE AND FLOW or you'll need a memcal burned to suit. Exhaust is a good next step I suppose, just do some research and try not to end up with yucky nasty V6 POS drone like 90% of V6 exhausts out there (including mine).
    High performance pulley kit..... I don't think you need to worry about that yet so throw that one off the list for now, probably ever.
    Plenty of advice floating around here already mate, there's a brilliant thread on Ecotec modification somewhere, I can't find it at the moment. Maybe some other kind soul will know where it is..
    edit: found..... Buick and Ecotec V6 Performance Upgrades
    Sam
    WTB: mulberry VN interior parts
    Nov 2008
    well the first i have to do is change all my flulids n oils.
    im getting a short shifter kit.
    gettin high ratio rockers.
    gettin a stroker kit.
    new exhasut.
    custom air intake ( 3 inch aliminum pipe, with silicone bends into a bored out throtle body) cold air intake SS inductions
    heavy duty clutch.
    and gettin high performance brakes.
    i already have high performance ignition leads.
    and i am fully customizing my interior and sound system
    and i recently purchased a VY Maloo Style body kit for my VS. its a nice xmas present for me
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    new exhasut.
    heavy duty clutch.
    i already have high performance ignition leads. <-- these do nothing dude
    You do realise don't you that a stroker kit is not just something you get slapped together in a day or 2 at your average workshop right?
    1995 v6 vs executive
    Dec 2008
    ive heard that a cold air intake puts on 8 kw on but not sure if you have to do more to get that power gain
    3.8 VR Executive S2/ Kawasaki zxr250
    Aug 2008
    West Auckland NZ
    Is it supercharged? because mace engineering does a 10psi pulley kit for cheap. Im assuming its supercharged if you want a pulley kit if not dont worry bout one. could you imagine the price on a gilmour belt that long. and bigger injectors arent nessecary unless you want to put more fuel in and with more fuel you need more air
    And by the way how much are stroker kits worth for v6s and do they do any signifigant increase in power on a super6?
    Federation
    Against
    Rotary
    Tossers
    Nov 2008
    Quote Originally Posted by Thrasher View Post
    Nah it's not supercharged. It's on the to do list.
    Stroker kits range from 1000 - 5000 dollars, just depends on where you get them from and how much performance gain you want out of it.
    Nov 2008
    Quote Originally Posted by savage1987 View Post
    yes i am aware of the time it takes to put a stroker kit in.
    i have nothing but time. i cant drive my car for another 2 months soo yeah. will have pleanty of time to do all this work
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by DOC Sleepa View Post
    lol........
    if you're putting a CAI on because you think then you can say your car has (stock + 8) kw then good for you. With V6s it's not about power dude.. just modify them for efficiency / a laugh. Also the power gain depends on so many things man, I don't know who told you 8kw is the magic number but they're either just saying what their particular car made, which is useless info to you anyway, or they are just dribbling ****.
    Sam
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Power increase with a cold air intake is all relative to the ambient temperature, and how long / at what temperature the motor has been running.
    If your car is running hot because you've been thrashing it, and it's 5deg outside, then a front-bar cai is going to be doing a LOT for power. However if you just turned the car on, and it's a 30 degree day outside anyway, a cai isn't going to be doing much at all.
    Just having a cai there doesn't give you magic power
    The 1972 HQ Kingswood
  15. #15
    Nov 2008
    hey, so whats the go with a performance aliminium radiator.
    they worth a look, i think i saw some around the 300 dollars mark on ebay brand new?
  16. #16
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by Morton View Post
    Mine does it was like going from a V6 to a V8
  17. #17
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    waste of time if yours is working fine. No gains in having a shiney radiator, except street cred with the ricers.
    Reaper
  18. #18
    Nov 2008
    Quote Originally Posted by VrWagz1 View Post
    Fair enough, mine runs fine its got a lil bit of damage to it (few dints here n there). but i wouldnt mind a shinny new radiator.
  19. #19
    Aug 2008
    Sorry guys not trying to take this off topic or anything but i removed the rear ressie on my VS Ute and well now it makes a great sound below 3500rpm that i love even if others don't because its only a V6 but how come it goes silent after like 3500-5500rpm? What causes this and whats the best investment a 2.5 Catback or Extractors?
    Thanks
    Matt
  20. #20
    Nov 2008
    limited slip differential
    has anyone got a good website or information on where to get a new or used LDS
  21. #21
    Morton's Avatar
    May 2006
    Your best and cheapest place is eBay. Next from that, is a wrecker. I picked up my complete brand new LSD centre with 3.7 gears, all shimmed up nice and tight in a full hub-hub setup for $500. The bloke paid $1200 to get it built the previous month (receipts and all) but found a locker with 4.11s two weeks later and installed that instead lol
    You can find great bargains on ebay
  22. #22
    Nov 2008
    Cool
    cheers for that
    yeah i've had a look on ebay LSD is a bit scarce though for my make.
    but i've found a few good deals going atm
    brake upgrades are goin for around 4-800 dollars which is a good 400 dollars less there RRP.
  23. #23
    Morton's Avatar
    May 2006
    You've got a VS ute? An LSD Centre will fit out of a VN/VP/VQ/VG/VR/VS for 100% certain. You just take that diff to a diff specialist, and ask them to put the centre from that, into your car. Should cost $300 for the changeover
    And I'm 99% certain that a live axle centre will fit straight into an IRS centre.
  24. #24
    VrWagz1's Avatar
    May 2008
    wollongong
    If your refering to the front twin piston caliper upgrade, just be sure to look at prices of doing it with a good second hand vt/z calipers and rotors. I got a set off ebay for $70. Cost me $80 i think for adaptor braided brake lines from the local brake shop and $40 for the egg rings to take up the space of the slightly ovesize rotor hub holes in the vt/z rotors. So $150 all up to make up my own kit, alot cheap than the $400-$500 they charge for kits.
    Reaper
  25. #25
    Aug 2008
    Quote Originally Posted by jokerflingo View Post
    Thanks
    Matt
    Bump anyone? Please not trying to highjack thread just didnt think this small question was worthy of another thread.
    Thanks Heaps
    Matt
  1. performance upgrade vl
    By adrian222 in forum Straight 6 Development And Modification
    Last Post: 22-11-2006, 07:10 PM
  2. performance upgrade for vl
    By adrian222 in forum General Discussion
    Last Post: 07-08-2006, 08:46 PM
  3. performance upgrade
    By Dingo in forum LSx Development and Modification
    Last Post: 02-03-2006, 04:30 PM
  4. performance upgrade
    Last Post: 01-03-2006, 02:27 PM
  5. performance upgrade prices?
    By stock_vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-07-2005, 08:15 PM
