Results 1 to 6 of 6
Thread: VS V6 running hot
    jakewaze's Avatar
    jakewaze is offline Jakewaze
    VN Spack S1 Auto
    Nov 2008
    Question VS V6 running hot
    Hi
    My vs runs very hot if you stop at traffic lights or drive slowly for longish periods. It hasn't overheated yet but it sits around 1.5 bars from red. If I put the aircon on though the temp never goes above 1/2 which is good, but I don't always need the aircon on.
    does anyone know what this could be???
    cheers
    UPDATE: I forgot to mention that it was recently put in to the shop cause it was pooring out coolant after each drive, they said it was a sticky thermostat and it was s upposed to be fixed. No it doesn't leak but it runs hot, the mechanic said maybe a sensor
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Probably due for a coolant change and a new thermostat. If its still pretty hot after that you can drop the thermostat to an 81* instead of the standard 91*
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd replace the coolant temp sensor which tells the ECU when to turn the cooling fan on - this should fix the problem (this would be what the mechanic suggested) they are cheap and simple to instal.
    VP Exec
    Jun 2005
    If I interpret the OP correctly, the thermostat was replaced by the workshop in an attempt to solve the engine overheating and spewing out coolant. Is that right?
    If the cooling system has been bled correctly after that work being performed (too many of these posts!), I'd go with the sensor or the sensor wiring/connector too.
    jakewaze's Avatar
    VN Spack S1 Auto
    Nov 2008
    cheers evey1, will replace sensor asap
  1. not running
    By Slipinit_sideways in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-02-2007, 03:37 PM
  2. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  3. Vn V6 Running
    By cohn in forum Parts And Other Items For Sale
    Last Post: 18-07-2006, 09:52 PM
  4. running hot
    By ads72 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2006, 12:44 PM
  5. VC with a 202 running in
    By Joes_meat in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-04-2005, 03:02 PM
