Results 1 to 6 of 6
Thread: VS V6 blows fuse cuts engine...
    VS V6 surf
    Oct 2008
    Default VS V6 blows fuse cuts engine...
    my Ecotec equiped hilux surf has just started this new prob now GRRRRRRRR
    ill start it up then somtimes it just dies after about 5 secs very occasionaly blows the fuel pump fuse ( no codes ) then when im driving it stops somtimes ill put into nutruel then itl start strait away.. iv cheaked the F/P wiring all good could it be a prob with the oil pressure switch also when driving it surges as the ignition is cutting in and out...
    None
    Aug 2005
    Adelaide, SA
    VS V6 surf
    Oct 2008
    thats not somthing iv given much thought i spose it could be shorting out the positive somwere do they do that iv never heard of that thing....ill look at it!!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    My money is on the oil pressure switch shorting out. Depending on how your setup is wired it might be possible to bypass the oil pressure switch to check this is the problem.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    ive had a vn that was cutting in and out just like that ended up being the ecu cutting the pump on and off new ecu and problem fixed
    VS V6 surf
    Oct 2008
    haha Hako was on the money!! iol pressure switch was the culprit!
    burnt it right out !!
    also the wiring in the car is is all factory commodore wiring...the best way to go!
  1. VC Commodore Blows Instrument Fuse??
    By vk4akp in forum Electrical Wiring / Questions
    Last Post: 01-12-2008, 07:55 PM
  2. VSII Cig lighter fuse blows with car charger
    By richardsworkcar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2008, 12:28 PM
  3. vt mirror blows fuse and c/control
    By vc213 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2007, 10:32 PM
  4. VT Horn Fuse Blows
    By brett 46 in forum Electrical Wiring / Questions
    Last Post: 28-03-2007, 06:54 PM
  5. ipod charger blows VS cigarette lighter fuse
    By jspillane in forum Electrical Wiring / Questions
    Last Post: 04-06-2006, 09:52 PM
