Results 1 to 8 of 8
Thread: VS ABS problem
    VS Acclaim s2
    Dec 2008
    Question VS ABS problem
    My VS ABS activates just as you drive off for about 2 sec's causing the brakes to come on by themselves. No warning lights on everything seems fine. Anyone else had this problem or a fix for it.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Sorry don`t know. But that sounds very dangerous I would be getting it looked at ASAP mate.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by dazzar View Post
    That is actually the ABS system testing itself. Mine does it every time I take off after staring the car. So it is normal unless your car actually comes to a stop while it is happening.
    MY RIDE
    VS Acclaim s2
    Dec 2008
    Thanx for the reply. My main concern is that this only started about a week ago and i have had the car for over 10 years. I'll keep looking .Cheers Dazzar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I'm not sure whether the VS has the ABS testing thing but I know it is later models. My VT had ABS and I didn't notice the ABS testing in that.
    Is the car actually braking when it happens or is it just a strange noise occurring?
    MY RIDE
    VS Acclaim s2
    Dec 2008
    The ABS motor comes on for a second or two and if you are gently resting on the brake pedal it pulses like when ABS controls a locking wheel under hard braking. Then it stops, checked the fault code for ABS shows #63 -Valve relay control fault. Where and how do fix that?
    94 VR Calais V8
    Aug 2007
    Sydney, NSW
    All commodores from the VN onwards run a quick diagnostic on the ABS module after having just started the vehicle. This test occurs the moment the car starts to roll forward or reverse. Its duration is about 1.5 secs during which time you can hear and feel this on the brake pedal. In all the years of owning commodores, I have never felt any braking effect while the test occurs, other than that you hear it.
    Now from what you have said so far, and the fact its behaviour has after 10 years caught your attention plus the fact an error code has now appeared, clearly you have a problem somewhere within the ABS module, as I'm sure you would agree.
    With an error like #63 - Valve relay control fault, I would be a little concerned driving the vehicle at all. Perhaps, dirt has somehow blocked some small passage within the ABS module, and a simple brake fluid replacement may unblock it and fix the problem, but I'm only guessing. If that doesn't work then alternatively replace the ABS module with a second hand unit from the wreckers.
    VS Acclaim s2
    Dec 2008
    Thanx for the reply. Have pulled fuse to ABS and done a safe controlled road test in a flat quiet area. Did a couple hard stops with out and with ABS connected no problems . Will still investigate further to see if it is a sensor or maybe Ive got some crap on the sensor rings in wheels. Only appears to be front wheels affected its just niggly thing I'm being anal about Thanx again i will post a thread if i fix it
  1. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  2. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  3. Sub Or Amp problem???
    By calais_cruzin in forum Car Audio
    Last Post: 17-01-2007, 01:44 PM
  4. VY Ute Sub Problem??? please help
    By liquidforce_134 in forum Car Audio
    Last Post: 30-05-2006, 06:17 PM
  5. Problem with car. Help!
    By wazzad in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-10-2005, 01:37 AM
