Results 1 to 6 of 6
Thread: Need Help - Vibration in FPS wheel
    Mar 2008
    Default Need Help - Vibration in FPS wheel
    I need some help as I am stuck on what to do?
    Ill start from the beginning
    I got all the brakes done with resurface of the rotors + 2 new tyres on the front.
    The next day when driving I felt grinding coming from the wheel but only when I was braking and braking at a slow speed, this felt like metal was grinding so I took it back to the mechanics and they could not find anything wrong, the mechanic came for a drive and because the grinding i s random it didnt happen when he drove it. He pulled of the wheel had a loko and said it all looked good.
    The next day after I was driving on the freeway and I could feel a vibration in the wheel and the floor of the car. This vibration feels like there is a lump or uncircualr tyre on the car. Its not the wheel balance because the steering is not vibrating from side to side its more like I have something stuck on the wheel like a bolt etc.
    Checked the tyre and it looked good, just to be sure I went back to Bob Janes they didnt even take the tyre off came back in 3 mins and said it was the link tin bush's.
    Took it back to the mechanic who had a look and said they r fine a little worn but ok, he is till stummped on what it is but said bring it on monday, the only prob is I have to go away and drive up the coast on monday so I am a little worried about what is causing this?
    Anyone heard of this problem before? I suspect its the tyre.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    A quick check is to change the front tyres for the rear - use 2 jacks and have an assistant. This will prove/disprove your theory. Good Luck
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Mate of mine had a problem with a michelin tyre recently. Tyre had a lump in it from delamination. He said it felt like there was a bump in the road at each revolution of the tyre. Check the tyres again for lumps, the new tyres and the old ones.
    I'm confused by your posts tho, is it only when braking, or all the time, or random.?
    Mar 2008
    yeah ive never been good at explaining things like this -
    The vibration happens at speeds in excess of 60kmh, i cant really feel it any slower than that. But definatley feels like a bump in the tyre, the faster I go the faster the vibration occurs.
    Guess Ill go to bo janes get them to rotate the tyres if it happens on the tyre I suspect ,then make them replace it (xenon 225/50/r16) i was trying to save money on these tyres as they were the cheaper option.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Starting to sound more like a rack end or tirerod end a bit worn and not a tyre problem. It would be very rare for even an el-cheapo tyre nowdays to delaminate when new and you'd imagine that would be one of the first things Bob Janes would check. Would also be felt at lower speeds....or thats the experience I've had.
    Mar 2008
    today i swapped the wheels front to rear and checked the pressure, the problem has seem to be gone, I can feel a little vibration but not enough to be concerned, hopefully this will get me up the coast without doing my head in. I bet the problem comes back
  1. Vibration in front wheel
    By lemonaed in forum General
    Last Post: 02-12-2008, 09:34 PM
  2. Intermittent vibration - Front left wheel
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2008, 02:51 PM
  3. Vibration Through Steering Wheel
    By DannY_P in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2006, 09:26 AM
  4. slight vibration from steering wheel
    By Takhuma in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-06-2006, 09:11 PM
  5. slight vibration from steering wheel
    By Takhuma in forum General
    Last Post: 19-06-2006, 05:16 PM
