Results 1 to 2 of 2
Thread: Sensor Replacement...
    mrhotdog is offline What Would Jesus Do?.....
    2003 VY S1 Acclaim
    Nov 2007
    Adelaide, South Australia
    Default Sensor Replacement...
    im goin to replace my coolant temp sensor and sender pretty soon, as well as thermostat as mech reckons this is what is causin my ****e cooling problem. any special way to replace sensors or is it just in and out. also which one is which as there is a big and small one...
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It's the bigger one closer to the DFI module. Preferably use a ring spanner to loosen but a shifter will do at a pinch. Before you fit the new one wrap some teflon or plumbers tape around the thread.....if you haven't any then just instal dry as they usually don't leak. No need to worry about losing coolant as only a tiny amount should be lost.
  1. o2 Sensor replacement
    By VZ05 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-06-2011, 08:07 PM
  2. oil sensor? replacement needed
    By -=ApheX=- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-08-2008, 11:34 AM
  3. oxygen sensor replacement
    By boogs86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-09-2006, 09:56 PM
  4. O2 Sensor replacement
    By Gosling1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-09-2005, 09:31 AM
  5. O2 sensor replacement
    By Xonar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-07-2004, 05:43 PM
