hi i was just wondering if the vr acclaim had power windows cause i have the fuse for it and i think i have the wiring im not sure i only have manual windows handles what does the the wiring look like under the stereo is it to plugs one smaller than the other ???
1994 Holden VR Acclaim Ecotec V6
1992 Holden VP Berlina S2 retro fitted with VS Acclaim Interior
vr acclaims did not have power windows unless it was optioned for it. and yes 2 plugs of diffrent sizes. should be able to fit it your self if you have the time
so why does it have the wiring but not the buttons it has a fuse and all where is the power windows module????
this is what i have in my car does that mean i have the wiring yeah how do i check if i have a power module and the window regulators????
VR VS FRONT POWER WINDOW LOOM A1 SS HSV CALAIS - eBay, Other Car Parts, Accessories, Car Parts, Accessories, Cars, Bikes, Boats. (end time 19-Dec-08 06:03:00 AEDST)
you wont have the regulators because you have wind up handles and they are diffrent
my equipe is based off the exc so was the acclaim but my equipe has electric windows
so maybe all car's on the exc line had the wiring for the electric windows and maybe other add on things. just means you need to buy less stuff to upgrade
ohh and the power module is in the bcm i would think you would need a mid series bcm to do the windows etc my equipe has a mid bcm.
the only diffrent things i got on the equipe from a acclaim is power windows and adjustabol electric ariel.
the acclaims had the wiring for elec windows, i did the conversion over 2years ago, one of the best mods i've done.
The rear loom finishes in the B-piller so u'll need the loom from there to the rear doors, purchase the window regs, relay and curcuit-breaker (not a fuse!) theres a BCM bypass that u'll need to cut and join some wires, from memory green and yellow. Do a quick search, should dig up all the info you need.
yea no probs, i replaced my door trims with some from a berlina, will eventually retrim my originals and cover up the winder holes, then drop them back on.
