my mate has just got my manual conversion to put in his vr, and we cant find the wires for the reverse lights??
do we need the BCM module also or just the computer and memcal??
please help as he wants to do the convo A.S.A.P.
The complete Vn-Vr Manual Conversion Guide.
# The other two wires on this connector are pink and green, they are the wires for the reverse lights test this yourself by touching them together and looking at the reverse lights.
# To get the reverse lights working you will need some more wire to extend them to the gearbox. when you have enough length crimp a blade connector on each wire *Note they do not have to go onto the gearbox in a specific order (i had a spare loom sitting in the shed so i used the same colours to keep it factory looking.)
1994 Holden VR Acclaim Ecotec V6
1992 Holden VP Berlina S2 retro fitted with VS Acclaim Interior
what parts do i need?
what flywheel? 8 bolt or 6 bolt ?
you need 8 bolt, 6 bolt will only fit VN series 1
If I keep my VR long enough might consider converting it to manual, is it pretty hard to do?
Some parts are a bitch. In theory it's straight forward as everything should just bolt up, but there is a LOT of stuffing around. Well worth it though.
