just wanted to say thankyou to everyone here .
my '95 vs v6 ute has had a miss in it only while cold until it had warmed up.
was like running on 4 cyl's etc . ran ok when given a boot tho .
in the process of checking things , i found the O2 sensors u/s (didn't check the rhs cause the lhs is easier to access), but thought this was not the cause of my miss ....
i found the gregory's manual showed the 4 wire heated sensors , but it wasn't untill i read here sumwhere that , as a test , you could cut the pink wire of the heater circuit to remove it from the system . i cut the pink wire , on the sensor side of the harness , of both left & right side sensors .
it ran perfect this morning on my way to work !
the next few morning runs should confirm that all is well ... sort of
the O2 sensors will be replaced eventually
thanx again![]()
welcome to JC
Glad to see a new member browsing the forums and having a read and a search. Good to see the threads/topics could help you out.
thanks for posting up your problem and what you did to fix it![]()
thanks for the welcome ephect .
someone mite , as i did , google 4 it 1 daythanks for posting up your problem and what you did to fix it![]()
