Results 1 to 2 of 2
Thread: ignition immobaliser????
    whitevrboi is offline Just another white vr.
    VR Executive S2
    Feb 2008
    Default ignition immobaliser????
    Ok so a little while ago I stopped my car, turned it off and left the key in the ignition for about 10mins and I didnt get out, I then went to start my car and it wouldnt start, the accessories and everything came on but it wouldnt start. After alot of stuffing around i locked it got a lift home, came back to try again and it started straight away. Now if I leave it unlocked for more than 30seconds or so I cant start it and I have to lock the doors using the remote unlock them then it starts
    Does anyone know what has happened here? I am guessing its an immobaliser issue, the thing is that before this incident I had sat in my car many times for more than 15mins or so and had no probs starting it.
    Any help would be great as its really starting to give me the ****s.
    Cheers Jack
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I think you may find that this is "normal" - if I leave the keys in the ignition for more than 5 mins I have to press the unlock button to disable the immobiliser before the engine will turn over. (you'll hear a swish sound). Previous times when you say you sat in the car for 15 mins and no problems maybe you had the accessories on.
  1. vk ignition
    By nezza in forum Electrical Wiring / Questions
    Last Post: 06-02-2009, 02:27 PM
  2. Ignition problem help needed, Ignition lead fallen out??
    By boourns in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2008, 05:04 PM
  3. MSD Ignition
    By sobvngrpa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2005, 09:58 PM
  4. Immobaliser
    By VN_BLUE_S-Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2005, 11:53 PM
  5. Engine Immobaliser
    By çlówŋ in forum Electrical Wiring / Questions
    Last Post: 04-02-2005, 10:16 AM
