Results 1 to 5 of 5
Thread: vs won't start
    AE86 levin
    Dec 2008
    Default vs won't start
    hi there I've been trying to figure out what’s wrong with mates 1999 VS ute for the last 2 day's the first problem was that it had no spark which we fixed by replacing that thing under the coil pack's after we did that it would not crank at all there was no noise coming from the solenoid on the starter motor and there was no power going to it, I found that the grey wire on they relay for the starter motor was not earthing so I striped it back a bit and just earthed it onto body and it cranked over but it wouldn't start even though it's got spark and I’m confident that it's got fuel as I can hear the fuel pump working and there's power getting to the injectors. I’ve got know idea why it won't start anymore and any help would be appreciated.
    Cheers.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    checked the fault codes ? The thing under the coil packs is the DFI module.
    Check the connections are good at the DFI and CAS.
    AE86 levin
    Dec 2008
    AE86 levin
    Dec 2008
    I looked at the fault codes and it came up with 12 so that's fine the CAS was replaced last month, I think the injector's might not be earthing properly as well as the starter motor dose anyone know where the earthing point is for these are.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    Quote Originally Posted by KE70GT View Post
    injectors earth in the ecu they get direct power from the eng fuse i think
  1. VR won't start
    By killerkentucky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2008, 09:30 AM
  2. where too start
    By vr_owner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2006, 08:21 AM
  3. VS didn't want to start?
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2006, 10:13 PM
  4. Won't start without "start ya bastard"
    By Steven M in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2005, 12:12 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
