Results 1 to 9 of 9
Thread: VR Parcel Shelf Speaker Size
    VRII Executive V6
    May 2008
    Default VR Parcel Shelf Speaker Size
    hey i would just like to know what size speaker would fit under the parcel shelf without any modification.
    Also if anyone has changed the rear speakers of a VR which ones you put in and what size?
    Thanks
    VS Commodore Omega
    Apr 2005
    For the easiest job 6" coaxials will do the trick, can even use the rubber gasket from the factory speakers - best of all it looks completely factory. For a bit trickier job (but bigger size) you could try 6.5". 6"x9" would require cutting (both the shelf and possibly metal unless you use a spacer) or building a new shelf, and splits would require the tweeters be mounted somewhere (roof or in the shelf) which can make things a lot trickier. I got some pioneer 6" 2 way coaxials, wasn't too fussed because I wanted something to fill in the rear (got splits up front) and they do the job perfect, ~$50 from JB
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Pretty much any 6.5"s will fit. There is no need for splits as you will never hear the difference from the front seats. I have 6.5" Alpine Type-s coaxials in mine (~$150) and they are fine
    <RaBBiT>'s Avatar
    <RaBBiT> is offline Follow the White RaBBiT>>
    95 VS Berlina 5.0,VN Wagon 5Spd 5.0L
    Nov 2007
    [SA]
    well 6.5 don't always fit i have focal 165v2' and they didn't fit but other brands do fit so its hgard to say but to be on the safe side go 6inch gd luk with it
    If Barbie's so popular, why do you have to buy all her friends?
    VRII Executive V6
    May 2008
    ok so when you guys say it doesnt fit what do you mean? is the mounting wholes not lining up the diameter too big or does it touch the grill on the parcel shelf?
    VS Calais S1
    Jul 2006
    Kadina, SA
    i guessing they would mean the holes dont line up.. i just replaced the ones in my vs with some 6" pioneers i got from JB Hi-Fi ($83) and they lined up perfectly..
    VR V6 Manual
    Aug 2008
    Central Coast, N.S.W
    my vr had a indentation in the shelf so i could just pull it and make a hole for 6x9 and they fit in like 5 minutes just screw to shelf or buy spacers like i did
    VRII Executive V6
    May 2008
    <RaBBiT>'s Avatar
    Nov 2007
    [SA]
    its not about linning up the speaker it self can be to big and not fit in the hole lol but yes gd choice just go the 6"
  1. VY SS rear parcel shelf speaker wires
    By ris00 in forum Car Audio
    Last Post: 15-09-2010, 09:09 PM
  2. Parcel Shelf Speaker Size?
    By Kaindya in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2008, 01:16 PM
  3. 99 vt parcel shelf speaker wires
    By VT1988 in forum Car Audio
    Last Post: 21-11-2007, 02:40 PM
  4. VX Rear parcel shelf 6X9 Speaker Electrical Question
    By Decksta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-06-2006, 08:12 PM
  5. Vt Parcel Shelf Speaker Grills
    By clinker42 in forum Car Audio
    Last Post: 10-05-2006, 03:11 PM
