Results 1 to 7 of 7
Thread: VS BLowing Engine Fuse
    VS
    Dec 2008
    Default VS BLowing Engine Fuse
    HI all
    I have a VS commodore that just died. Seems the Main engine Fuse (20amp Blade) has blown, so i replaced it and that blu as well, tried a few different ones and they all are blowen. SO i guess there is a short somewhere. If there are any Auto sparkies here, what sort of money would it take to fix?
    Seem the fuse blows as soon as the engine cranks to start. Completley died while driving.
    Basically i want to know what sort of money i would be up for as its pretty close to Xmas and not a good time for this **** to happen.
    VS
    Dec 2008
    AN update
    This morning i put in a new fuse and the car started. But as soon as i accelerate the car died, blew the main fuse again
    VRII Acclaim
    Jul 2005
    Having a look now, that fuse looks like it supplies power to the EFI relay, oil pressure switch, fuel pump relay, fuel pump, ECU - possibly more.
    I would start by swapping the EFI relay and fuel pump relay - see how that goes. Next buy a new oil pressure switch and put that in. Pretty cheap and easy to install. If that doesnt fix it may be the fuel pump at fault. Hope this helps.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    i'll put 2 bob on the fuel pump or oil switch. Maybe oil pressure switch as oil pressure would go up with a rev, so it might be shorting out under pressure.
    Reaper
    vs
    Jan 2010
    Hey guys mine is doing excactly the same thing did u work out the problem??
    06 VZ SVZ Wagon
    Apr 2006
    Central Coast, NSW
    had the same problem with a mates vn a few months ago, cleaned off the wires going to the starter motor and has been working fine since. but your car started but his wouldnt.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by HoldenGal99 View Post
    Try pulling the fuel pump relay - if the fuse does not blow when trying to start then put relay back in...try to start and then if it does blow the fault is probably a short in the fuel pump or the wiring to the pump.
  1. Blowing fuse VS V6
    By TrustNo1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2008, 04:48 PM
  2. My car keeps blowing fuse
    By bellasmummy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2008, 06:24 PM
  3. A/C blowing fuse VP
    By twasm6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2006, 07:29 PM
  4. HELP main fuse blowing
    By danny1987 in forum Electrical Wiring / Questions
    Last Post: 16-02-2006, 09:10 PM
  5. horn fuse blowing
    By Ian J in forum Electrical Wiring / Questions
    Last Post: 04-11-2005, 10:38 AM
