The locksmith did everything for me - replaced & cut the blade, and replaced and cut the key head (with the buttons on it. For $20 cheaper than holden
That should have been "REplacement Key"
Im wanting to get a new key for my VS cause the buttons have deteriorated. Can you just buy the buttons anywhere or would I have to replace the whole key? I know Holden charge about $100 for a new key and have heard some locksmith places charge less, but are they actually copying the signal to a new key or just replacing the black part?
Mr Minit charges $110 for a key and head or $70 for the head only including programming so the latter is the way to go. They're at most shopping centres.
Thanks for the tip guys!
Went to Mister Minit today and had it done for $80 and it only took the guy 10min. Saved myself at least $20![]()
You can buy replacement heads off ebay. You just pull it apart, put the pcb and metal key into the shell of the new head. The only problem is
A) its not that cheap - ranging from $20 to about $50 for one with a chev logo
B) Its risky, you could damage something if youre not careful
C) You have to glue the two halves together, which is tricky and, if not done right, will annoy you.
I gotta key head off ebay for 29 bux, and my local floating locksmith charged 12 bux for cut and program
My Ride:
'94 VR V6 BT1. 15" roh with 225's, stocky with bellmouth removed, OTRCAI, homemade airfilter, B&M Stage1 shiftkit, .490 boost valve. Corvette servo.
Lappy runnin EFILive in a semi stock interior.
WANTED: VN/VP/VR/VS Standard
Memcals.
WANTED: Standard front bar from VR/VS. Prefer alaskan white but will take anything.
Newcastle/Maitland/Central Coast.
Email me
hyp3r4l3rt@hiptop.com.au
