Results 1 to 4 of 4
Thread: vs interior wiring and acc. into vr exec
    vr executive 3.8
    Mar 2008
    Default vs interior wiring and acc. into vr exec
    Iv jus bought a written off vs auto berlina en i want 2 put the level 3 cluster, trip comp, cruise control and power windows in my vr manual executive...
    Can anybody give me an idea on wats involved in doing so?
    Also is it easiest 2 convert 2 climate control or can i use the standard?
    VRII Acclaim
    Jul 2005
    Lots of work - mainly with wiring etc, but can be done. You should find instructions on here if you keep looking around, particularly for the cluster.
    vr executive 3.8
    Mar 2008
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Drama is the bcms will be different vs to vr (they use different serial data to talk to the ecm for theft control between models) so if you tried to install the vs loom you will have to rearrange the bcm plug wiring to suit you original bcm. Chances are your vr has a low series bcm and the vs has a mid or high series one.
    You cant use the vs bcm that the cruise/power windows use without changing the ecu (autos and manuals use different types)and vs manual ones are hard to find.I found it easier to strip the wiring you need out of the donor loom and install it into your original loom...so it isnt a simple plug and play exercise to swap over looms.
    I used a vp separate module type loom for the power windows and made a adapter relay to get cruise control to work with the stalk buttons in my vr manual while still retaining my old low series bcm.For the l3 dash Iused wires and plugs from the l3 dash loom and connected them to my original loom....my heater/air con remained as it was.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. VN exec wiring
    By voxbox in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-12-2008, 06:05 PM
  2. VR exec 5l, clubby kit & interior and vy front bar..
    By commy92 in forum Vehicles For Sale
    Last Post: 30-01-2007, 10:49 PM
  3. VZ Commodore EXEC/SVZ Wiring
    By darksidewa in forum Electrical Wiring / Questions
    Last Post: 14-06-2006, 02:07 PM
  4. VN Exec Wiring ???
    By knightwolf in forum Electrical Wiring / Questions
    Last Post: 05-08-2005, 09:58 AM
