hi i have a 95 VS commodore my car is missing (doesn't run well) when the car is in gear (eg D)
and you put the brakes on or if you let the brakes off and just rolls along.
The car runs well if your driving or it's in Park.
and i just replaced spark plugs and leads
please help
thanks
how do you misplace a car? is it stolen or you just dont know where it is??
lol..... missing as in doesn't run flash
Missing ususally happens when accelerating not really when you back off. maybe you have dirty injectors or dirty throttle body that needs cleaning. Also possibly a coil
sounds like a vaccume leak around the booster! more info would be required tho...
The car works fine when ur driving
and it does it on both fuels. (it's Duel fuel)
it just does it when the car in Drive and stopped (not movin)
and sometimes the engine light comes on when it's cold
and which error code does it give you ?
how do you find out a error code
and the engine light only stays on for about 1km When car starts first time
of the day after that no light at all
dude , look up the how to section. There's a black ' computer plug just above the pedals under the dash. Get a thick paper clip or thin piece of wire, bend it and stick it in pins 5 and 6 on the top row of the plug counting from left, and turn ignition key to ON. don't start it though, and count the flashes .... HOW TO SECTION dude,
Also you don't need to post the same question twice - your previous post just a few days ago asked the same question:
VS auto transmission car skipping
Sowing more seeds doesn't always bring about a better crop!![]()
