Page 1 of 2 12 LastLast
Results 1 to 25 of 43
Thread: Car wont rev when cold
    HSV VT GTS
    Dec 2008
    Default Car wont rev when cold
    hey guys when my engine is cold and i go to rev it, it coughs and splutters and wont rev unless i use a minute amount of accelerator pressure. it is like its not getting enough fuel or something, but only when cold.
    when the car is warm/hot it is fine.
    Any ideas?
    VRII Acclaim
    Jul 2005
    Have a check for codes and start with a service if you havent done one recently - do your filters (particularly the fuel filter), oil, plugs etc and maybe leads if you havent done them for a while etc. May not fix your problem but its a good starting point anyway.
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Can you smell petrol when you open the bonnet? I know the VP and VR's are prone to dropping the fuel line to the injectors off the block only a tiny bit but enough for them to leak in the cold. May have still been a problem with the VS's
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like the coolant temp sensor isn't telling the ECU the engine is cold resulting in a lean mixture till the engine warms. They are cheap and easy to replace.
    HSV VT GTS
    Dec 2008
    have only just bought the car and drove it for a week before i flew out O/S, the day after i bought it i replaced the front engine mounts, oil and oil filter, and new gold plated plugs. when i get back i am getting a new set of leads and will change the fuel filter.
    i dont remember smelling petrol under the bonnet but i will check again when i get home and get the fuel lines looked at.
    i know that it makes it hard to answer questions when i am overseas and cant do the things your telling me but will start with these when i get home. was just wandering if this was a common problem or not.
    thanks for your help
    HSV VT GTS
    Dec 2008
    Quote Originally Posted by hako View Post
    ok cool thanks i will replace that when i get home too, where in the engine bay is it?
    should i do the water temp sender at the same time?
    Y-Series Senator Signature
    Jan 2006
    Willall Racing
    im pretty sure hako is on the money.
    The engine is too lean when its cold, thats your problem.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Its the fatter one under where the top radiator hose meets the engine .... nearer the DFI module. When you buy a new one you'll recognise it when you look there. Best to undo with a ring spanner but a shifter will do at a pinch. Apply PTFE tape or a sealant to the threads if you want to but it's not necessary.
    HSV VT GTS
    Dec 2008
    HSV VT GTS
    Dec 2008
    ok i replaced the WTS and still doing the same thing. had the whole cooling system flushed out and refilled with new coolant, new thermostat, and new CTS.
    when i first start the car and rev it, it coughs and splutters like it is going to stall and if i give it a decent stab, it will stall.
    any ideas anyone? putting new leads in tomorrow, plugs have already been replaced.
    Bite off more than you can chew, then chew like hell - Peter Brock
    VX SS M6
    Jun 2005
    mine does the same thing some times, but mostly after i disconnect the battery. maybe it could be the tps or iac?
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by muggo05 View Post
    Any ideas?
    is your car running LPG ??
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    HSV VT GTS
    Dec 2008
    nope no lpg
    HSV VT GTS
    Dec 2008
    *BUMP*
    anyone got any ideas?
  15. #15
    HSV VT GTS
    Dec 2008
    *BUMP* anything?
  16. #16
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You said you replaced the "WTS" which means water temperature sender....the one you need to replace is the CTS - coolant temp sensor (which talks to the ECU).
  17. #17
    PSYKO PHOENIX's Avatar
    PSYKO PHOENIX is offline AHHHH brain fart
    1995 VS Commodore v6 ecotec
    Nov 2008
    rotorua, NZ
    sounds a bit like an issue im having wth mine, when its cold and a give it a lil kick it coughs and splutters untill it gets higher up the rev range, could it be the same issues?
    you dont turn a holden off
    you power it down!
    for any one who asks, holdens dont leak oil, there marking there territory
  18. #18
    HSV VT GTS
    Dec 2008
    yeah i just saw your thread! any progress yet mate?
  19. #19
    Nov 2008
    rotorua, NZ
    nope unfortunatly not, at the mo iv got no gas in the tank and no money at all till monday, so im prety gutted bout the whole thing lol
    you power it down!
  20. #20
    HSV VT GTS
    Dec 2008
    i might take mine down to mechanic mate today to get the regulators checked out. he is going to do my leads to which he said were "arcing out".
  21. #21
    HSV VT GTS
    Dec 2008
    sorry i was wrong i did replace the CTS, not the WTS. might get the IAC looked at then.
    i'm getting shit fuel economy too, barely can get 400 to a tank and i'm granny driving it everywhere.
  22. #22
    Nov 2008
    rotorua, NZ
    howd you get on with the mechanic?
    you power it down!
  23. #23
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    I had the issue before, similar to your starting issue
    As well as
    * It sometimes stalling for no reason (its an auto)
    * Terrible petrol consumption (Made V8's look cheap - Mine's a V6)
    * OCCASIONALLY would receive error codes... shows oxygen sensor lean and something else
    * Pile of black smoke coming out when starting car
    Was a faulty fuel regulator.
    Hope this helps
    OzJD
  24. #24
    HSV VT GTS
    Dec 2008
    Quote Originally Posted by OzJD View Post
    As well as
    Hope this helps
    OzJD
    *mines never stalled on me (auto as well)
    *same really bad fuel concumption
    *has been doing it with no error codes
    *no smoke at all
    will check error codes again just to make sure, getting the leads done today which i will get the IAC looked at too so will post back this afternoon after the mechanic has a look at it.
  25. #25
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    one thing causing all the problems with fuel ecconimey and what not will be the air flow meter un plug it and it will rev but its not driveabol like this, plug it back in and it will run like crap again
  1. Problem -S/Charged V6 Cold Start wont idle
    By colgf in forum General Discussion
    Last Post: 06-09-2007, 05:47 PM
  2. climate control blowing cold aircon on cold days
    By stackner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2006, 03:24 PM
  3. Cold air
    By VNCommo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 02:49 PM
  4. Which is Better POD or Cold Air
    By Slip in forum V6 Development And Modification
    Last Post: 27-01-2005, 01:21 PM
  5. Cold Air For Vk
    By adsVN in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-04-2004, 05:38 PM
