Results 1 to 10 of 10
Thread: easy off door panels??
    PSYKO PHOENIX's Avatar
    PSYKO PHOENIX is offline AHHHH brain fart
    1995 VS Commodore v6 ecotec
    Nov 2008
    rotorua, NZ
    Post easy off door panels??
    hey all, ive been having a problem with my left rear door not central locking, ive tryd crc down the lock but thats made no improvement, so im gunna take the door panels off on the inside so i can have a look at it
    heres the question
    is there an easy way to get the inside panels off?
    or a step by step guide?
    i no its easy but i wanna make sure i get it right and do as little damage as posible
    thanks in advance for your help!!
    <RaBBiT>'s Avatar
    <RaBBiT> is offline Follow the White RaBBiT>>
    95 VS Berlina 5.0,VN Wagon 5Spd 5.0L
    Nov 2007
    [SA]
    try searching there should be a thread some were, but u gotta pop out the orange bit on ur lock and there is a screw there, um there is three scews on the map pocket, 2 in the bit u use to hold onto, and the rest is clips, which tend to break but more can be bought from motor traders so don't be afraid if u break some. also to prevent damaging the air vent it is best to take that off too as the trim is wedged under it and can be broken when taking the trim off
    If Barbie's so popular, why do you have to buy all her friends?
    VR
    May 2008
    Yeah, mate. It's pretty straight forward. Just take out all the screws, door handle etc.
    Then take out the lock, you need a hooked bit of wire/blade to pull the orange section of the lock-knob forward, allowing you to take the knob off, exposing another screw.
    Next is the window winder. There's a wire clip up underneath the winder that holds it onto the window mechanism. You need another piece of hooked wire to reach in and un-clip it. Not sure if you get my drift. Just pull the hand out a bit (gently) so you can have a squiz & see what I mean.
    Once thats done just lever the skin off. Use a flathead screw driver or paint scraper to jimmy the anchor pins out. You might break some, but yeah, easily replaced. Just don't force it. If it's not coming off easily, it's probably because its still screwed in somewhere.
    VT
    Apr 2005
    QLD
    Pull back wether strip.
    Insert C4 and detonate.
    Drive to next postcode to find your door trim.
    **warning** there may be some minor panel damage to door skin.
    Nov 2008
    rotorua, NZ
    Quote Originally Posted by VT-565 View Post
    now thats what i call DIY!!!!!
    ill just nip down to the local arms dealer and get some, you reckon 500 grams will be enough?
    its real cheep down here, 50 cents a gram!!
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by PSYKO PHOENIX View Post
    screw 500grams.....do myth buster style and place 10KG in there.....hey if ya gonna do it you will wanna do it right the first time.
    VT
    Apr 2005
    QLD
    $500 a kilo! wicked. I have a few tree stumps at home to get rid of too.....
    Quote Originally Posted by jas98 View Post
    10kg will turn the whole car into silver glitter.
    I'd pay to see that.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    hmm...*rubs chin* i have a old vn wreck out back
    <RaBBiT>'s Avatar
    Nov 2007
    [SA]
    whoops yeah i forgot about the window winder lol i have power windows:P
    Nov 2008
    rotorua, NZ
    great sucess!! no big explosions but i did manage to get the door apart and replace the central locking motor, it was way easyer than i thought it would be, although trying to get the window winder to come off was a bit frustrating hahahahaha
    but its all good cuz now my left rear locks when all the others do and unlocks 2 YAY!!!!!!
    hahahaha
    thanks for your help guys
  1. vn aero door panels
    By fatvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-02-2008, 11:32 AM
  2. WTB: Aero Door Panels
    By Jazack in forum Swap / Wanted to Buy / Trade
    Last Post: 13-11-2007, 01:47 AM
  3. Door replacement...easy or what?
    By andy05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2006, 12:01 AM
  4. VR-VS Door Panels
    By wes_v8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2005, 11:13 AM
  5. How do I take the front door panels off a VR?
    By jrennie21 in forum Car Audio
    Last Post: 21-06-2004, 04:57 PM
