Results 1 to 15 of 15
Thread: VR - VS Cluster question
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default VR - VS Cluster question
    Just purchased a V6 VR cluster with what was ment to be 212000 kms on it.
    Get it home and on the bottom it has SV 92054707 V8 on it and 146555 kms. Look this up and it is a VS 250kph cluster from 95 onwards (has a 220kph speedo in it now. Also hasHSV pt number 12 J 950702 on it.
    My question is is the VR and VS front cover the same? thats the bit that has all the lights along the bottom.
    and 3 Dangerous non ABS VN's
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Yes they are. Some icons are in different positions. On VR the have press remote where low fuel is on a VS I think. Stuff like that any way. Same Icons on them but in different positions. I can have a look at one for you and get the order of the icons if you want.
    88GreenVN's Avatar
    Jun 2006
    Left side |BATT|ABS OFF|LIGHT|ENGINE|OIL|BRAKE|<- |(P)|FEUL|
    Right side |SPD|TEMP|->|HI BEAM|PRESS REMOTE|AIR BAG|CRS|ON|PRW|
    This is the run down on the VR plastic on a VS cluster. The PCB has 1997 printed on it.
    The only difference I can see in the PCB connector numbers in a VR one I have has 2 for air bags and the VS has only 1.
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by NickVR View Post
    Sounds like you got it sussed out then.
    Not quite. The VR PCB has 2 air bags on C3 the VS PCB has 1
    Is the VS plastic cover Different
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    What are you doing with the cluster?
    Surely the speedo going to 250 would have given away it was a HSV one lol
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by STEALTHY™ View Post
    Speedo is gone
    Edited first post Opps
    STEALTHY™'s Avatar
    Jan 2005
    LOL, its probably the one i bought years ago and stole the speedo unit out of it.
    cheers sexy
    88GreenVN's Avatar
    Jun 2006
    Checks cluster for Stealthys grubby finger prints
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by 88GreenVN View Post
    I didn't touch it. Skye did all the work.
    cheers sexy
    88GreenVN's Avatar
    Jun 2006
    Ok your off the hook
    Real bonus was the low k trip computer
    STEALTHY™'s Avatar
    Jan 2005
    The one i had was a low K one too. I only needed it for the speedo unit tho. If your speedo unit says calais international on it, its def mine
    cheers sexy
    88GreenVN's Avatar
    Jun 2006
    Hmmmm will take it apart tonight now to have a look.....
    Where did it say Calais International on it? on the speedo PCB or the cluster PCB.
    I'll take a photo of the sticker. Someone with a non original VS 250kph cluster may want the PCB with an original has sticker on it
    STEALTHY™'s Avatar
    Jan 2005
    LOL, i don't think it does say it. Was just ****ing with you.
    cheers sexy
  15. #15
    88GreenVN's Avatar
    Jun 2006
    Bugga - you blew it - we could have had all the International owners rippin out the cluster to have a squizz.
  1. Quick cluster question
    By Clacker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2008, 04:25 PM
  2. Dash Cluster Question
    By fitzy2005 in forum General
    Last Post: 29-08-2006, 08:13 AM
  3. VN Calais Cluster Question
    By vinnywelsh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-12-2005, 08:08 PM
  4. Another cluster question
    By gdunkley84 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-09-2005, 11:55 AM
  5. Vn Cluster Question?
    By maveriick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2004, 10:23 PM
