Just wondering if it is possible to fit a gearbox and clutch assembly off of a VN - VR onto a VS?
It will be a T5 so yes it is possible. This is the gearbox that was fitted to the series 1 vs models. Apart from the gearbox and clutch assembly you will also need to source a vs manual loom and computer. Do a search on this forum as there is heaps of info covering this topic on here.
Thanks guys
not series 1 vn though, somthing with the flywheel bolts i think, not the actual gbox though.
