I have a VR SS and the steering is creaking when I turn the wheel I just had all bushes replaced and a 28pt inspection from pedders and they said it needed a good power steering service but was otherwise really good any help would be appreciated
Probably coming from where the shaft goes thru the bulkhead below the brake master cylinder - there is a plastic 'grommet' which gets dry and groans when you turn the wheel. Dodgy steering shops/mechanics have been known to make a lot of money oiling these and then charging for a new steering rack etc. You can grease it or spray with WD40 or similar - best accessed from under the car on a ramp or on the gutter.
You need to get under the car and find the steering rack. Look around for the shaft that is coming from the steering wheel to the rack. Where the shaft goes into the inside of the car there is the grommet hako is referring to that stops water, dirt etc coming into the car. Its hard to see, so you just have to use your hand and follow the shaft up as far as you can go. You will feel the grommet. You then get your lubricant and give it a good spray.
Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
Don't be stupid. Power isn't measured by the size of your tacho
