Results 1 to 13 of 13
Thread: Tailshaft issues
    Jun 2005
    Default Tailshaft issues
    Ive been getting a banging kind of noise coming from the rear of the car. Mostly when taking off in 1st. It isnt too obvious when im by myself in the car, but the other night when I had a full car load, no matter how softly i took off, it would start banging quite badly. Is this a tailshaft or centre bearing issue? Car is a manual V8
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    probably uni joints i'd say or cv joint i doubt its the bearing but could be best to get under and have look easier to check if you take it out you should be able to hold it either side of the uni's and twist there should be no movement if there is replace uni's for center bearing check to see if rubber is deformed replace center bearing if it is cv joint a little harder usualy need to pull it apart and check the races to see if they are damaged easy to tell by scoring and stuff might need to be repacked with grease aswell
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Seeing as its worse when the car is loaded it could be the exhaust hitting somewhere or one of the control arms shot allowing the diff housing to move.
    Jun 2005
    im sure the front uni is fine. replaced not long ago. might have to see if its the exhaust hitting
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    ha, im getting this too when I take off, only if I half plant it :P its good because it keeps me driving her nice and easy, though the uni's closest to the diff and the trans both need replacing and my pinion seal is gone, every now and then it sprays a little more out of the diff
    If I wasn't so lazy i'd fix it next weekend when I can afford all of the parts but meh, we'll see how I like this attitude when i'm walking
    Jun 2006
    Western Aus.
    Centre bearing. Mine did the same, failed and everytime I loaded it up it just bashed around under the car.
    Hot Lap Motorsport
    VS Berlina
    Feb 2007
    DOH, so I need to do the diff, uni's and a CV, so much for dont do burnouts and the car should last, what a crock of crap, I should go bag it up all the time like my mate used to with his VR, that thing was bullet proof.
    I hate bad luck, wreckers here I come, money there you go.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    How low is your vr? Seeing that its worse when loaded with people in the back ive seen this happen with a mates vr. Turned out to be the rear uni where it bolts ontop the diff was hitting up onto the floorpan in the tailshaft tunnel and had just about worn its way through the metal. Would be worth checking out.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    How are the rear wheels as far as camber goes? If you reverse, does it look like it has more camber? If it does then the diff cradle is cracked. But I just think it is the exhaust hitting where it goes under the axle.
    Visit my Facebook page
    Jun 2005
    ive had a look and the exhaust is pretty close to the drive shaft. wouldnt surprise me if thats the problem. how is this usually fixed?
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    being IRS and the fact that the exhaust travels under the axles when the car is fully loaded the there would be more clearance between exhaust and axles/diff. if it is hitting the exhaust there should be some witness marks
    i'd be checking the diff cradle
    Body by Holden, Soul by Brock
    the Legend will live forever
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    In the top picture, where the twin pipes are expanded and go over the pieces in front, check how close they are to the control arm.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Any vibrations when this happens (or other times??)
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  1. VR Tailshaft Q....
    By holdenboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2008, 11:05 PM
  2. separating tailshaft and tailshaft lengths
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2008, 08:18 AM
  3. vt-vx tailshaft
    By yeah,yeah in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-07-2006, 09:45 AM
  4. V8 tailshaft
    By yaf_ool in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-09-2005, 11:16 PM
  5. Tailshaft Issues
    By vnvkuserabuser in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-07-2005, 12:35 PM
