i have just finished fitting a raptor kit and when i was done i was getting an error code temp sensor voltage too high (code 15)
i havent touched this and dont know wat it is where it is or anythign unless its the temperature sender which is for the readout on the dash but yer duno??
Have a read around, Error Code #15 and #16 - Coolant temperature sensor high voltage / unstable voltage
There should be enough info around to help you out. There are two temp sensors, one for the gauge in the car and one for the cars computer. They live near the alternator, maybe you have knocked the connector off by mistake?
G'day, after i fitted my supercharger to my VR, i got the same code. Turned out to be that earth wire on RHS of timing case that attaches to the long stud, has two black wires that join into a round terminal that slides over stud and then tightened with nut. Anyway, that wire attaches to the tensioning pulley lower stud. Trace wire back about 7-10 cm into the spaghetti tubing and look for breaks in wire, mine were hard and brittle and not earthing correctly giving me weird ass codes like that, the engine cooling fan would also come on and off intermittantly... Cutting wires back, re-soldering and re-fitting corrected my problem, hope it does the same for u! Good luck![]()
my cooling fan just stays on all the time and i have ocersized radiator so it dont get hot anyway just hate the little yellow light ***ing ****s me but yer i shall try tracing the earth backas that is wat i first thought as well
Get it fixed mate. When the voltage is too high it thinks the ECM thinks the water temperature is too low so the vehicle will stay in Open Loop mode running the engine a little rich to heat up then engine and water faster. While in this mode it stops paying attention too all of the other sensors except for the O2 and the TPS sensor...you will be using more fuel also.
Think of it as driving with choke stuck on.
i havent jsut knocked it off i smashed it off not sure how but yer top half was smashed off loom was stil plugged in but i placed it back on and engine light went away but i shall replace it as soon as i can
cheers for all you help.
