Results 1 to 6 of 6
Thread: HSV VR 185i specs
    VR CLUBSPORT
    Nov 2008
    Narangba
    Default HSV VR 185i specs
    Hi peeps,
    Just looking for some help.
    I noticed one of my rear tyres has been scored on the outside fouling the inside of the arch.
    Just thought it was due to sagged springs - but i checked again and the rear tyres are 255/45/17, the fronts are 235/45/17
    What size should be on there?. I have standard wheels.
    I also want to check my ride height to try and see if the springs are shagged. I need to get new tyres due to wear on the inside, but thats pointless if the springs are shagged cos they won't last long either. Then i can get the alignment/camber checked out.
    Anyone know what the ride height should be as standard?
    Current measurements from hub centre to wheel arch are
    F= 357mm
    R= 365mm
    Thank you :-)
    [SIGPIC][/SIGPIC]
    HSV VR 185i Auto
    Jun 2005
    255 seems a bit big. 235s normally, or 245s
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VR HSV Clubsport
    Jun 2008
    Hobart,TAS
    VR CLUBSPORT
    Nov 2008
    Narangba
    Thanks for the tyre info. Any recommendations on cheap (ish) tyres. People seem to rate Maxxis ?
    [SIGPIC][/SIGPIC]
    HSV VR 185i Auto
    VN S
    Dec 2008
    you can pick up kuhmo excsta's for around 160ish, there are a few cheaper brands, ive got talon triangle on the front of mine, and there are obviously more expensive tyres
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    tyres are one of those area's where cheaper certainly isn't best. having said that, i've just fitted some accelera tyres which seem to rate fairly well in the last Wheels mag tyre test.
    those are fairly wide treads, however should be fine still as i ahve seen 265's on commodores. maybe if it's been lowered and not had a camber correction kit fitted it may be causing your problems
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. 185i question
    By mosone1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2010, 10:01 PM
  2. Best LOUD exhaust for 185i 304
    By Cobez in forum V8 Development and Modification
    Last Post: 23-07-2008, 12:00 PM
  3. VT 5.0 HSV TOP END SEQUECTIAL 195 KW will it suit VR HSV 185i
    By Damo83 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-09-2007, 06:44 AM
  4. will a vt 5.0L alternator fit a 98 vs stato 5.0L 185i ?
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2006, 09:56 AM
  5. vs 185i exhaust
    By jdjones in forum Parts And Other Items For Sale
    Last Post: 28-09-2005, 12:07 PM
