Results 1 to 10 of 10
Thread: sluggish startup on VS
    97 VS Executive
    Nov 2008
    Default sluggish startup on VS
    Hey im having some problems with my 97 VS. Ever since iv had it whenever i turn the key the car struggles to start, it usally takes between 2 - 5 seconds to actually start up. The other day however i tried starting it up and I got nothing it just made a clicking noise. After a while it eventually started but I was just wondering if anyone has experienced this before and has fixed it. Iv already had a look through the forums and i dont think the problem is due to bad contact with the key.
    Any help would be appreciated cheers.
    1993 VR Executive Commodore
    Oct 2008
    VRII Acclaim
    Jul 2005
    Sounds like a dieing battery, bad connection on the battery or your starter motor. If you have a multimeter you can take some measurements to get an idea of how the battery is or take it to a battery shop and they will test it for you. Start by checking the battery connections - they must be nice and tight. If the battery is a few years old, replace it. Good starting point anyway even if it is the starter motor.
    VS Commodore Omega
    Apr 2005
    If the car stalls while you're driving then it could be the crank angle sensor (CAS), was having similar problems; car wouldn't start sometimes and would almost randomly. When it doesn't start next try pouring cold water on the CAS and see if it starts - when they're damaged they get very sensitive to heat I think.
    VZ SS-Z
    May 2006
    When i first read your post, i thought starter motor for sure. But where you said clicking, i can only say the battery. As kopper69 said, it's the best starting point. Failing that, depending on your climate, the brushes in the starter motor can cause sluggish cranking. I'd be starting with the battery though.
    97 VS Executive
    Nov 2008
    Quote Originally Posted by kopper69 View Post
    I replaced the battery when i first bought it, it didnt really change anything. Ill check the connections and get back to you
    Quote Originally Posted by VS Omega View Post
    The car has never stalled when driving however I will trying pouring water on the CAS next time it gives me trouble
    Shaundy's Avatar
    Shaundy is offline BMW Technician Apprentice
    VS Executive S2 BT1
    Jan 2009
    Yeah my VS also does this. Sometimes it will just quickly crank over 3-4 times and it will start. Other times it will crank over a slower and with more revolutions while if its really bad it will crank slowly and for a reasonably long time and each crank will 'stop solidly' with an audible sound.
    This VS is guarded by shotgun 4 nights per week - You guess which 4!
    My BT1:
    [SIGPIC][/SIGPIC]
    Vs V6 ute
    Jan 2009
    Quote Originally Posted by Shaundy View Post
    mine does that too - when the car's hot it cranks a lot slower than if it's cold. doesn't take more revolutions to start tho. it this a common ecotec thing?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Also try moving the T Bar to N and back to P before moving the key - sometimes a worn inhibiter switch can cause this problem.
    Swordsy's Avatar
    Swordsy is offline mmmm beer....
    VUII Maloo R8 - XJR1200 - XR450R
    Nov 2007
    Newi NSW
    My VS used to do both these things, new battery made it start quicker and a new key fixed the "dead" start. My old ducks VS also did the key thing untill she replaced it.
  1. sluggish??
    By Tom04 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2006, 11:37 PM
  2. Sluggish
    By Brasso in forum V6 Development And Modification
    Last Post: 13-02-2006, 06:45 PM
  3. Sluggish? VT 5.0
    By VT Calais 5.0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-04-2005, 07:10 PM
  4. Sluggish VP V8
    By Chuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-01-2005, 12:42 PM
  5. Gen 3 sluggish
    By Baldric in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2004, 12:11 AM
