Results 1 to 4 of 4
Thread: dual mass fly wheel to rigid
    VT olympic
    Aug 2008
    Default dual mass fly wheel to rigid
    hey, does anyone know wat is required to convert a dual mass flywheel into a solid/rigit one? or is it just swap n go? thanks tom
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    swap and go, but you will need the whole kit as the clutch plate will need to have the spring masses now etc.
    VT spac super6
    Nov 2008
    Riverton sa
    yep have to swap for a solid one and get a full clutch kit to suit
    worth it tho.. id rather f**k a $200 plate than a $1500 fly wheel
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I've never done this so really I know nothing but I'd imagine the if the solid flywheel comes with the T5 gearbox and the dual mass flywheel comes with the Getrag gearbox there would be more to it than a straight swap ....also one is hydraulic actuated and the other cable plus splines and pilot bearing diameter may be different.....
  1. New Exedy HD clutch and rigid flywheel installed
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2007, 07:15 AM
  2. Mass air flow sensors ?
    By cody_(ve/R8) in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-09-2006, 03:21 AM
  3. dual mass v6 flywheel
    By vt1998 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-07-2006, 08:58 PM
  4. Mass air temp sensor
    By brookie211 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-05-2006, 03:39 PM
  5. Mass air temp sensor
    By VNXTCY in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-11-2005, 09:06 PM
