Results 1 to 9 of 9
Thread: green ignition light
    VS SII Executive
    Dec 2008
    Default green ignition light
    i was walking by my car and i saw somethign green inside, i got to my car and the green light next to the ignition was on. is the green light next to the ignition ment to stay on all night???
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    is it only the newer ones that light up with the remote button? ie it'll stay on until you lock the car with the remote and come back on when you hit the unlock button...
    It isn't meant to be on 24/7 though.
    VS SII Executive
    Dec 2008
    hey, well could it be a sort of warning? because i have no light in the roof, as i broke it when i was taking the roof lining out, do you think its telling me that i have a light out???
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Probably more likely that when you broke the roof light circuitry it screwed with the ignition light. The roof light is supposed to go off when you lock the car so they're probably on the same circuit.
    VS l67 statesman
    Dec 2008
    Im sure the all lights in the interior are run througth either the BCM if you have one or the headligth switch..I had a vp berlina and the same thing happened Except all of the interior lights stayed on because I accidently arked some wires while working on the steering colunm ,which shorted out the timer(part of the headlight switch) ,the only way to fix it was to replace the headligth switch
    6/1996 VS Commodore S Pack Automatic Utility
    Nov 2008
    I might have a solution, I thought that the instrument dimmer switch (next to headlight control switch) had three settings. In fact, it only had two, I had it at the highest setting, thinking that it was just the brighest setting for the instrument cluster when it was a 'stay on permanently' setting for the interior light. This means that when I closed the door, the interior light AND ignition barrel light (the work in unison, btw) would stay on until I removed the fuse. I finally resorted to the owner's manual and realised my mistake. It may be possible you may have accidentally done the same, however your interior light globe is not working, leaving your ignition barrel light on only.
    Just a thought.
    VZ SV6
    Oct 2008
    Newcastle NSW
    Quote Originally Posted by vsspac696 View Post
    Just a thought.
    I did the same and drained my battery over and over and over until I realised.
    VS SII Executive
    Dec 2008
    cheers vsspac696
    PROBLEM SOLVED
  1. ODOMetere Green Light??
    By saad3000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2007, 03:03 AM
  2. No Right Green Indicator Light..
    By Megilu in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2007, 07:04 PM
  3. light green berlina pics please
    By phat_com in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-10-2006, 11:07 PM
  4. Power Mirror Green Light
    By BANGERS88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2006, 01:55 AM
  5. Green Light
    By StatOmaN in forum Electrical Wiring / Questions
    Last Post: 27-09-2005, 10:50 AM
