Results 1 to 4 of 4
Thread: Power window question
    VZ Calais
    Aug 2005
    Mackay Qld
    Default Power window question
    Hi guys, merry christmas.
    I have replaced the pwr window reg in my Vs statey, the problem is, when i fitted the glass, the window [front] is not in the rubber seal.
    Instead, it is between the rubber & the guide.
    Will i need to remove the whole lot again, or can i just remove the slide & put the window back in the groove?
    Cheers, Col.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    merry Christmas too you too....
    i think you will need to monover the glass in the door to get it back in to the slide. you can just loosen off the regulator but this requires new pop rivets or pop the slide out of the window, but other way the window need to be moved the slides do not move, well not very far anyways.....
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    You shouldn't need to touch the regulator. Just make sure the window is in the lowest vertical position before you manouvre it into the correct position in the tracks. It's a dirty, dirty job.
    VZ Calais
    Aug 2005
    Mackay Qld
    There is a 10mm bolt at the bottom of the slide.
    It holds the slide to the door.
    When i remove it, there is about 3mm play in the slide.
    I think the rubber is holding the slide in.
    Without pulling the door apart again, [i will have to, i know], do you think this will be enough movement to get the window back in to the groove?
    I am trying to not have to re-rivet the bloody thing again!
    Cheers, Col.
  1. Power Window Switch Question. I have searched...
    By libardu in forum Electrical Wiring / Questions
    Last Post: 26-10-2008, 10:18 PM
  2. Power Window Up
    By AdamAnt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2008, 03:55 PM
  3. vn-vs power window kit
    By winton in forum Parts And Other Items For Sale
    Last Post: 09-12-2007, 11:14 PM
  4. power window question
    By crav_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-05-2007, 12:59 PM
  5. Power window goes down but not up
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2006, 10:34 AM
