i rang up a place today and asked how much for a 2.5 inch sports exhaust from the cat, for my VS V6. i was quoted 340 all installed is this a bit much or what do you guys think??
thats abt the right price.
shop around, can get them for $220 -250 fitted if you go to the right places, im talking V6 btw.
yea thats a bit much i recon.
here in sa i can get a 2.5" cat back exhaust system installed for $230 on pretty much any commodore, if any of you boys reading this post are interested, Carline / S & M motorsport at st agnes are the ones to go to, their ph number is 82644445 ask for Marty. He does an awesome job.
yeah i payed $320 for a 2.5" cat back with a single glasspack muffler.. the exhaust cost me $220 but i payed an extra $100 for a decent tip.
The VS is slightly dearer because of the way the cat is and the brackets on the front muffler. You would be hard pressed to find a VS live axle 2 1/2" cat back under $250. The IRS ones are cheaper for some reason.
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
but will vs sedan 2.5 inch fit a vs ute?
couldnt have put that part any better
So basically guys, if your after a common 2.5" catback exhaust you shudnt be paying over $300 for it. probably $280 max. As for the tip, they shouldnt cost more than $40 (for a really good one) and any more than $20 to tack weld on.![]()
It is cheaper to buy an off the shelf system these days though as they are jigged up and mass produced. When you say "custom" what you really should say is "fabricated". Custom generally means a one off and there is nothing special about a Commodore that needs a "custom" system.
Fabricated systems in terms of individual components plus labour work out more expensive.
Estimates:
3m of pipe at $40pm, $120.
Front muffler $120.
Hangers and clamps $30.
Labour 1-2 hours max $70-$140.
even at 1 hour you are still looking at $340, supply and fit an off the shelf system, $280-$320. And it's mandrel bent.
To fit an off the shelf item takes around 20 minutes, unless you are really quiet it isn't cost effective to fabricate a system for such a common car.
