Results 1 to 4 of 4
Thread: to isolate which cylinder at fault...
    VZ SV6
    Oct 2008
    Newcastle NSW
    Default to isolate which cylinder at fault...
    because of bottom failure, to see if its just a specific cylinder causing knock will is it possible to disconnect individual injector's wiring connector and run the engine? Will this damage the computer or anything... back in the day before EFI i knew you could just short out spark plugs but just want to be sure so I don't damage the computer or anything non-engine related which is going to be replaced anyway.
    If so, and the noise completely goes away, is it possible to drive with only 4 or so cylinders (keeping in mind the engine is going bye bye anyway)
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    haha, thats an awsome idea, It shouldn't hurt the computer, or anything really other then the Engine itsself.
    6 5
    4 3
    2 1
    FRONT
    That is the cylinder layout, so it should be pretty basic, I cant say it is safe though, but it shouldnt hurt anything but the engine in theory :P just push the little wire clip in on the injectors and pull the plug.
    VZ SV6
    Oct 2008
    Newcastle NSW
    lol you mean probably not safe as in it could blow up/throw something through the block as i've got my hand over the motor... ouch
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    lol running on 4 cylinders should t be a problem seeing as its a dead motor anyway...as me mates VS was only running on 4 cylinders due to a burnt out coil pack (read nothing on the meter) and he drove about 40 k's like that at 110k's so yeh l;ol
  1. Fs sa 4&6 cylinder nos kit
    By FUN304 in forum Parts And Other Items For Sale
    Last Post: 18-09-2008, 08:58 PM
  2. Is this VP fault, V6 fault or just bad luck?
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2006, 10:46 PM
  3. what does 6 cylinder L mean?
    By V3N0M in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-05-2006, 07:36 AM
  4. What 4 Cylinder To Buy ?
    By projectaero in forum General
    Last Post: 26-10-2005, 11:24 PM
  5. Fault light came on but reports no fault
    By VRBerlina05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 07:21 PM
