Results 1 to 9 of 9
Thread: vs 5.0l temp issues
    Oct 2007
    Default vs 5.0l temp issues
    ok so my vs has seen the half way mark and the notch above that aswell on the temp gauge it used to sit on 1/4 and never move from there. i have replaced the thermostat radiator cap it has antifreeze antiboil coolant, the water pump is not even a year old and the engine fan/clutch seems to be working properly. i have a spare water temp gauge in the shed im going to put in and see what happens but what other things should i be checking where does the temp gauge sit on other 5.0's? any help would be much appreciated cheers, brad
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    If your in traffic, that may be ok. But if its just in regular travelling then i would say theres an issue there. Take some temperature readings and see if it actually overheating and then chase it from there. Nothing worse then a bum gauge or sensor unit giving you the run around. Im not sure of the exact temps you should run, but im imagining about 90-95 degrees. Some one else here may know exactly????
    Reaper
    Oct 2007
    Quote Originally Posted by VrWagz1 View Post
    ill put the aftermarket gauge in and see what happens can someone tell me what the temp should sit on? i was thinking maybe the clutch in the fan may be dying should i just **** off the fan and get an elec thermo?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    The temp should sit at whatever your thermostat is rated at. If you have a 90deg thermostat, then your temp should be around 90-95deg.
    Easy way to tell if the clutch fan is working:
    1) turn the car on
    2) get up the front with the engine cover off
    3) rev the throttle spindle, and see if the fan speeds up quickly.
    If the clutch fan IS dying, then you're probably best off getting another one. They do a very good job, and drain very little power compared to always-on fans. You can throw in twin-thermos from an AU, but it's a lot of money and hastle when a clutch fan is cheap and always turns, keeping the motor very cool.
    Also keep in mind we're coming into hotter weather, and this will have effects on your car's temperature. Instead of 15-20deg air flowing through the radiator, it's now over 30 during the day, which will increase operating temperatures.
    My VP used to never get above the first dash in winter, but would run hot as an oven in summer.
    The 1972 HQ Kingswood
    commsirac is offline Banned
    vx
    Aug 2007
    Quote Originally Posted by SICKTG View Post
    Rather than an aftermarket gauge, Id buy yourself an infrared temp sensor. You can get a fairly accurate temp reading on most things, in an instant. They cost ~$40, less than an aftermarket gauge.
    You can see which bits of the motor are getting hot, whether the coolant is circulating, how much temp drop through the radiator etc
    If your clutch fan has had it, replace it with something that will work just as well.....a new viscous clutch unit.
    There is usually a steady decline in performance of the fans where it can change from having only ~15% slip when new when engaged and increase to over 80% with use.
    How do you tell if they have had it? If its very bad, the fan will barely increase above idle rpm when you rev the motor. But for optimum performance there is only one way to test for sure and that is to measure fan speed versus pulley speed, you need either a strobe or optical tachometer.
    Typically most dont bother and use a few rule of thumb methods:
    Here's one more:
    When stopping the motor, if the fan doesnt stop within one spin, its stuffed(this applies to the acdelco units fitted to holdens, but not to all viscous units which may keep spinning depending on what temperature they are at)
    or alternatively, if the motor is stopped when it is overheat condition, try spinning the fan by hand, if it spins more than half a rev...its stuffed.
    Oct 2007
    ill test the fan out tommorow cheers for that^ and the reason i said ill throw the gauge in is becuase i already have one sitting in the shed... i was watching it driving home tonight it would get to half and drop back a notch almost as soon as it reached the half mark. does anybody know off hand how much the clucth part of the fan is worth new? and if i was going to put a thermo in id put a thermostatic switch in to run it thanks for your help so far guys
    vx
    Aug 2007
    Buying new, the acdelco ones from your holden dealer at a guess would be around the $100 mark, the same for the craig davies units.
    There are other brands, but my experience with some of them is that they dont always work to spec.
    Ive had more success with 2nd hand genuine units that Ive picked up for $5 or even two I found on a nature strip!
    Unless they have been stored vertically, it is hard to tell from spinning the units by hand if they are stuffed or not. If you buy from a wrecker, just get an agreement that you can refund it if it is no good. Given that they can be fitted in ~ 10mins, do it while you are there.
    Oct 2007
    i may just put an elec unit from an el ford in does anybody know if the v8 computer has a thermostatic switch even tho they didnt come with thermo's?
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    If you decide to replace your viscous fan just buy the centre bit not the entire unit (which includes fan blades). The fan blades are usually OK (unless they have been damaged in an accident etc.) and just buying the centre unit is much cheaper.
  1. Q's regarding Coolant Temp & Intake air temp sensor
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2009, 05:08 PM
  2. gauges oil temp and engine temp
    By vzon20s in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-11-2008, 05:31 PM
  3. Electric oil temp and water temp gauges
    By FRESH_VR in forum General
    Last Post: 02-09-2008, 04:27 PM
  4. What temp should my VP run at?
    By richie_cky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2006, 12:33 PM
  5. VP V8 temp
    By MasterOfReality in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2004, 08:52 AM
