Results 1 to 8 of 8
Thread: whats the best way to seperate ball joint on VS ?
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Question whats the best way to seperate ball joint on VS ?
    OK so you undo and remove the bolt that holds it in, then what ? bash the hell out of it ? can you jam a wege in the crack the bolt goes through to open it up ? Thanks.
    other
    Apr 2006
    ferntree gully
    Quote Originally Posted by greenacc View Post
    yes indeed hit the most soild near the bolt and it will come apart
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    If it the tie rod you are talking about undo the nut and turn it upside down and screw most of it back on and hit it with a copper faced hammer or put something over the nut so you dont burr it over with a normal hammer.
    If its the main ball joint you are taking out just undo the nut and take the bolt out and by wedging something in the gap to spread the joint it will slip or push out...no hitting necessary
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    VXII S Super6 Manual LPG
    Oct 2004
    Townsville QLD
    Or buy a tie rod end remover, its a tool.
    Will save u heaps of time.
    Stoke my ego, click the scales!!!
    Stoke it!!!!
    LOVE IT!!!!!
    greenacc's Avatar
    VE Berlina
    Jul 2008
    yeah i mean the main ball joint , the one on the outer end of the control arm. I did one side today with a small wedge but i guess it wasn't wide enough so the arm needed a few hits tp get it out. Will try a thicker wedge on the other side and see how it goes. Does the tie rod end remover work on ball joints as well or just tie rod ends ? cheers guys.
    Oct 2004
    Townsville QLD
    The tool is more for just the tie rod ends. Makes the job so much easier!
    As the others said, for the ball joint, just undo the nut and remove the bolt.
    Then it should be fairly easy to get out. I used to soft faced mallet and whacked on the bottom a couple times to loosen it.
    Stoke it!!!!
    LOVE IT!!!!!
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by markovr View Post
    spot on. one decent hit normally pops the tie rod. the problem with some of the tie rod removal tools is that they damage the boot. if re-using the tie rod thats a bad thing
    Body by Holden, Soul by Brock
    the Legend will live forever
    greenacc's Avatar
    VE Berlina
    Jul 2008
    the passenger side ball joint came out real easy. job done. thanks guys
  1. ball joint?
    By TWOJZ in forum General
    Last Post: 25-06-2008, 09:11 PM
  2. Replies: 16
    Last Post: 03-03-2008, 12:31 PM
  3. Lower ball joint!
    By SweetWagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-10-2007, 11:54 PM
  4. Ball joint removal
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-04-2007, 07:52 PM
  5. Lower Ball Joint VP
    By PaulW in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2005, 06:53 PM
