Results 1 to 8 of 8
Thread: Auto fluid checking Question
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Default Auto fluid checking Question
    Hi all I having a blond day I just checked my auto fluid on the vs.
    Had the motor running, in park, on level ground.
    I can`t get a good reading fluid is foamy.
    I need fluid?????
    I did a search
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VS Commodore Omega
    Apr 2005
    Not sure what could cause foaming, definitely not normal though - when was the last time the car had a trans service?
    VS_Pete_1's Avatar
    Dec 2007
    Due about now. It`s got bubbles on the dip stick.
    I haven`t added any fluid yet.
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Quote Originally Posted by VS Omega View Post
    My understanding was that foaming was caused by an overfilled transmission. That said I have always seen bubbles on the dipstick since I bought mine (90000km). It had one transmission service at 90000km and another recently at 160000km and the service didn't change anything.
    If this is a symptom of something I would like to know.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    all above is correct but ill add something else. trans can foam the fluid for a couple of reasons one being coved bye over filling but the other can be due to low level of fluid. low fluid levels can cause air to get in to the system and cause cavatation of the fluid also cooler lines that have a small leak could be sucking air in to the lines as well. best solution would be to drain and refill.
    also if you had low levels in the trans you would notice harsh shifting and slipping bands etc over fill would cause leaks if not addressed quickly.
    the other one could be worn out fluid, as fluid ages the anti foaming agents could be just worn out just like engine oil etc. or has become contaminated from wearing transmission components etc
    best advise is to do the trans service
    VS_Pete_1's Avatar
    Dec 2007
    Thanks guys I was only saying to GF I`m due for service at least it is running ok. Service coming up
    VS Commodore Omega
    Apr 2005
    Quote Originally Posted by VS_Pete_1 View Post
    I did a write up on how to do the service, if you or anybody reading this wanted to give it a read it's over here: DARKCOLD Tutorial: Changing the transmission fluid and filter on many Holden Commodore models (VS, VT, VX, VY) with the 4L60E Automatic Gearbox (could be helpful etc.)
    VS_Pete_1's Avatar
    Dec 2007
    Thank you good read man.
  1. auto trans fluid loss
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-01-2007, 08:16 AM
  2. VT Fluid question
    By TriK in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2006, 05:15 PM
  3. auto trans fluid changing
    Last Post: 07-03-2006, 05:16 PM
  4. Brake Fluid and Auto Trans Fluid.
    By Melchior3 in forum General
    Last Post: 20-02-2006, 11:49 AM
  5. VR V6 Auto Fluid Check?
    By Driver 111 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2005, 05:32 PM
